Author Topic: Exerion .ini help needed  (Read 1438 times)
Apollo
    • Eight Bells
« on: May 27, 2007, 04:27:55 am »
I'm using an arcade monitor and the arcadevga card. I can't seem to find a resolution or .ini file setting that will play Exerion without cutting off the lower part of the screen unless I turn on hardware stretch and doing this turns the picture to poop.
Does anyone have a setting that works for the game?
MUST PLAY EXERION!
Thank you
FrizzleFried
    • Idaho Garagecade
Re: Exerion .ini help needed
« Reply #1 on: May 27, 2007, 01:25:29 pm »
Exerion is a vertically oriented game.  I am guessing you are using a horizontally mounted monitor.  You are screwed.  Do what I did and build a separate vertically oriented cabinet or live with the screen being cut off.
Apollo
    • Eight Bells
« Reply #2 on: May 27, 2007, 03:47:09 pm »
I appreciate the reply but i play numerous vertical games on my horizontal arcade monitor and they are fine, Exerion is one of the only ones so far that I cannot find a good resolution or .ini setting that works.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: May 28, 2007, 06:13:49 am »
Exerion runs at 320x224 (vertical) with refresh of 61.419019 Hz.  Could it be the funky refresh rate?  What are the res & refresh rate of the games that work?
Robin
Knowledge is Power
