Author Topic: T-Molding  (Read 3876 times)
Jedirampage
  • Last login:July 08, 2008, 06:54:08 pm
T-Molding
« on: May 15, 2007, 06:18:20 pm »
Hey all,
Anyone know what stores carry T-Molding?  I bought some from Happ and its to small, around 1/8th of the trim is not covered.  Not very noticable but it will bug th heck out of me.  Dont care to order online again as i'd like to guarantee what i buy works.
Thanks,
Chris G
Re: T-Molding
« Reply #1 on: May 15, 2007, 06:25:09 pm »
Many people, including myself, have had luck with t-molding.com, if you want to give the online thing another try.  Measure twice, order once.   :cheers:
ScottS
  • Last login:November 01, 2007, 02:21:30 pm
Re: T-Molding
« Reply #2 on: May 15, 2007, 09:09:09 pm »
Good luck finding it locally; I've never had much luck. A very well-stocked woodworking store or a lumber yard that caters to cabinet builders might have it... but I wouldn't count on it.
I'd suggest you get some free samples from T-molding.com to determine the correct width for your project. Then measure carefully and place your order. Remember: much of their T-molding is shipped in 20-foot coils. Keep that in mind when ordering.
fjl
  • Pixels Rule!
Re: T-Molding
« Reply #3 on: May 17, 2007, 11:48:00 pm »
Would t-molding.com also be a good source for the slot cutter bit or should I buy from someone else?
Chris G
Re: T-Molding
« Reply #4 on: May 18, 2007, 11:47:38 am »
If you're looking for a quality bit, check this post Nitewalker wrote.  I followed his advice and have been very happy with the purchase.
Chris
fjl
  • Pixels Rule!
Re: T-Molding
« Reply #5 on: May 18, 2007, 11:13:31 pm »
He links to a 1/16 slot cutter. But on t-moldings web page practically all the t-mold featured says it comes with a slot width of 1/16"
Yet they show a picture under the picture of the t-mold and it always says the t-slot is 3/32"
wtf? So is it 1/16" or 3/32" ?
Cause you can also get a 3/32" slot cutter bit.
bleargh
  • Last login:Today at 11:41:19 am
  • ribbit...
Re: T-Molding
« Reply #6 on: May 19, 2007, 12:03:32 am »
You want a 1/16" slot cutter bit.
In the picture under the t-molding they show you a width of 3/32" as the total width of the spine with the edges on it.  If you put a 3/32" slot on your CP, the t-molding will just about fall out as you've got no pressure to hold it in place.
With a 1/16" (= 2/32") bit, though, you've got to compress the t-molding when you put it on, so its got something to help hold it on the panel.
fjl
  • Pixels Rule!
Re: T-Molding
« Reply #7 on: May 19, 2007, 04:49:16 pm »
Okay I get it. 3/32" is the manufactured size and 1/16" is the size to fit into so it can grab the insides of the wall. Should glue be used on it as well for a better hold?
Chris G
Re: T-Molding
« Reply #8 on: May 19, 2007, 04:56:02 pm »
Shouldn't be necessary.
  • Last login:Today at 01:37:16 pm
Re: T-Molding
« Reply #9 on: May 20, 2007, 06:18:32 pm »
Used a 1/16" slot cutting bit and no glue.
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
Re: T-Molding
« Reply #10 on: May 20, 2007, 06:51:10 pm »
Don't worry about the fit. If you cut the slot properly you'll actually need a rubber mallet or something similar to get the t-molding in the slot. It's a really tight fit.
It's 9am. I'm calling it a nite.
rackoon
  • Last login:February 16, 2026, 06:26:24 pm
  • I EAT PENCILS!
Re: T-Molding
« Reply #11 on: May 23, 2007, 03:41:24 pm »
Yo NightWalker flooring or counter top supply store sometimes have some laying about (at least the one I worked at did in Oakland. They sometimes use it with formica as an edging on commercial jobs, but its a shot in the dark with color and size. :cheers:
They treated me like an animal and that's what I became.
