Main > Main Forum
SNK LS-30 Optical
_Iz-:
The letters were V B A 0. (great pic BTW!)
I'd guess that V is voltage and 0 is ground this would make A & B signal. V and 0 are the 2 outside pins, the ones you said connect to the emitters. The emitters get voltage and ground so this would make sense. The detectors have voltage, signal A & signal B.
I'd say your guess is completely opposite to what it actually is...
Aceldamor:
Heh....
Good call Iz....Thanks for the tipper!!
I'll have to give that hook up a whirl....I could use a standard mouse hack to wire both of them up since it's only 1 axis just like a spinner right?
_Iz-:
--- Quote from: Aceldamor on April 17, 2003, 02:29:23 pm ---Heh....
Yes, and use mame analog+ to split the axis for you into 2 players.
