Main > Monitor/Video Forum
Soft-15KHz - slim new tool for 15KHz on normal vga cards
Ummon:
--- Quote from: SailorSat on February 05, 2008, 08:09:38 am ---hm... my current build (not public yet) includes an option for seperate "user modes" already, it should be possible to enhance those, so they don't get added with "fixed 60hz" to windows, but rather their "real" vertical refresh. 640x480 @59Hz anyone?
(there's an extra button "install user", and an extra textfile called usermodes.txt, so you don't have to modify the base modelines)
Though I have a copy of Winmodelines, as the site is down, everyone else is going to have to use your new version for that. Incidentally, it doesn't have any stock modes like yours, and I kept getting line errors so I gave up.
Slightly off topic: you might consider putting links to soft15 and cabmame in your signature or whatever.
tisurame:
--- Quote from: SailorSat on February 05, 2008, 12:51:50 am ---@bent98: emuspeed and soundsync should do the job
@silver: autoframeskip 0, throttle 0, tripplebuffer (or vsync) 1 - scrolling smooth as butter.
base mame is aiming for perfect emulation, and fiddling with the sound speed to match the video speed is not perfect ;)
So, using MAMEUIFX32 (or cabmame), do I also need to enable "Synchronize audio with video" ?
What about "Sync to monitor refresh" and "Refresh speed" ?
SailorSat:
--- Quote from: tisurame on February 05, 2008, 09:41:56 pm ---So, using MAMEUIFX32 (or cabmame), do I also need to enable "Synchronize audio with video" ?
yeah.
--- Quote from: tisurame on February 05, 2008, 09:41:56 pm ---What about "Sync to monitor refresh" and "Refresh speed" ?
don't enable.
SailorSat:
Build 37 online.
bent98:
Hey Sailor
Great new on the new release. I see this is whats new:
Alpha Build 37 (February 06. 2008)
"User" resolutions added. (usermodes.txt)
Attention! These are added with their real vertical refresh to windows.
Intel GMA and EGD drivers added. (experimental)
"doublescan" modelines featured on NVidia and 3Dfx.
New command-line switch.
-ius - installs "User" resolutions
Are you going to update the FAQ and get some more info how to utilize the new features?
Also on the doublescan" modelines featured on NVidia and 3Dfx. update does that mean I dont need to run a custom 15khz.txt file to fix that??
