Main > Monitor/Video Forum
Soft-15KHz - slim new tool for 15KHz on normal vga cards
SailorSat:
hm... my current build (not public yet) includes an option for seperate "user modes" already, it should be possible to enhance those, so they don't get added with "fixed 60hz" to windows, but rather their "real" vertical refresh. 640x480 @59Hz anyone?
(there's an extra button "install user", and an extra textfile called usermodes.txt, so you don't have to modify the base modelines)
bent98:
They way it stands right now with the limitation of 31 modelines for nividia cards, how many do we have right now? Just wondering with your new build of soft 15khz if it gives nvidia users room to add additonal modelines. Or is it keep exsiting modelines and just add addtional refresh rates?
SailorSat:
if I remember correctly... 29 @15khz modes, 2 additional @25khz, 6 changed @31khz
so if you only use 15khz, you can define two or three new modes without removing some of the base modes.
bent98:
Do you mind if I ask when you will be making your newversion of soft 15khz available to the public?
SailorSat:
--- Quote from: bent98 on February 05, 2008, 10:33:48 am ---Do you mind if I ask when you will be making your newversion of soft 15khz available to the public?
"when it's done" :)
