Main > Monitor/Video Forum
Soft-15KHz - slim new tool for 15KHz on normal vga cards
SailorSat:
TV with SCART = fine
TV with VGA = no need for Soft-15kHz; however you could use a set of 31khz lowres look-a-like resolutions
LCD TV = yup, use DVI/VGA whatever connection and native resolution. tune the rest in software.
As for the filters: here
Neo-Geo - 4 times enlarged, bilinear filter, triad6 "effect".
tman78:
Thank you. None of the png files from images.arianchen.de display, all are blank. Is that correct simply because they are filters?
Where in MAME do you place these filters?
Thanks again.
SailorSat:
IIRC you must place them in the "artwork" folder and set them in mame.ini.
The option is called "effect".
ved:
Hello SailorSat,
Have you an idea about windows 7 running soft15khz resolutions at only 30hz ????
You are my only hope :notworthy:
------------------------------------Original message -------------------------------
Hello SailorSat, and thanx for your work on this incredible Soft15khz.
As many people in this forum, i have a question : my ATI hd4670 work on win7 with soft15khz (Catalyst 12.2, monitor @25hz on 1024x768 and 1280x720) but... screen refresh rate is at 30hz instead of 60hz (interlaced)!!! and with 15hz resolutions it's the same problem on win7.
It seems that is windows7 problem ? have you informations or issue ?
Ps : all work very well on xp (1024x768 @60hz interlaced...)
Thanx for your answer
SailorSat:
I don't have a clue. I suspect either Windows or the Driver figures "oh interlace, lets halve the values then!"
