Main > Monitor/Video Forum
Soft-15KHz - slim new tool for 15KHz on normal vga cards
ac3:
Thanks Paradroid. :)
comatsu:
Thanks StarSailor.
Anyone can help me write a correct custom resolution for a Hantarex Polo 25?
When I install 15Khz modes in soft15Khz I only get the 720*480 resolution in windows, so I assume I will need to install it as a user resolution.
(I will be connecting the Polo to my additional vga port on my laptop through a jpac)
ved:
Hello SailorSat, and thanx for your work on this incredible Soft15khz.
As many people in this forum, i have a question : my ATI hd4670 work on win7 with soft15khz (Catalyst 12.2, monitor @25hz on 1024x768 and 1280x720) but... screen refresh rate is at 30hz instead of 60hz (interlaced)!!! and with 15hz resolutions it's the same problem on win7.
It seems that is windows7 problem ? have you informations or issue ?
Ps : all work very well on xp (1024x768 @60hz interlaced...)
Thanx for your answer
SailorSat:
--- Quote from: comatsu on March 13, 2012, 10:02:37 am ---Thanks StarSailor.
Most likely you will not see the additional modes as long as your internal screen is enabled.
Try using the Polo as seconds screen.
tman78:
I'm very late to this party, so please forgive me if I should post elsewhere.
I'm building my cabinet and have been putting off/researching monitor choices. I'd like to do an LCD as they are lightweight, relatively cheap for the size, plentiful, versatile, etc.
I have some questions about soft15khz that I've tried to verify but am not sure about.
* If I went with a TV, does it only work with SCART/multiport, or can you use an American TV with a VGA connection?
* Can you not use any LCD of any kind, because those only use one constant resolution (much higher than 15k).
* If I can use an older LCD TV, I was thinking of a VIZIO, but some have said skip the downgrading of the resolution, just connect to computer via DVI and use MAME options like scanlines to make the games look "authentic".
* SailorSat, I've heard LCD displays do well especially if you use your TRIAD-3 and TRIAD-6 settings referenced back in http://forum.arcadecontrols.com/index.php?topic=66402.720, but none of those images are available anymore, on this site or from http://files.magnanimous-majesty.de/nachtstern/images/misc/videofilter/triad6.png
Is there a way for you to make those Triad images available again, or are they not needed?
Thanks a lot, and if I'm off base on anything please let me know.
-Taylor
