Main > Monitor/Video Forum
Soft-15KHz - slim new tool for 15KHz on normal vga cards
savj14:
--- Quote from: SailorSat on November 26, 2007, 03:50:30 pm ---You won't have those tiny black borders left and right, but thats all difference.
Hmmmm so basically what resolutions will give me the best quality picture with the least amount of black borders?? I am little confused now ???
SailorSat:
Use the "base" resolutions added by Soft-15kHz, they work fine for almost everyone.
If you still want to create more "perfect" modelines, well grab yourself ADVV from AdvMAME, boot a DOS enviroment, and try to create it.
It's quite some work.
savj14:
Using PowerStrip I was able to add both 768 x 240 and 800 x 254, which did fill the screen better than the resolutions built into SoftK.
But using 512x384 for Vitua Fight did not work for me. The screen was all garbled. What settings for MAME should I be using???
Also, I cannot seem to find a resolution that will work for Killer Instinct(320x240)
I tried 320x240 and it gave me a black screen. I could hear sound but no image. Any ideas??
SailorSat:
The thing about resolutions is, that they are NOT universal.
It is simply impossible to make them all fill the screen without loosing pixels on either side.
For Killer Instinct try 321x240, although MAME should select the right resolution itself.
savj14:
All right Killer Instinct is working nicely now.
For some reason still can't get Virtua Fighter to work. The closest I got was a rolling screen.........Any suggestions???
