Main > Monitor/Video Forum
Soft-15KHz - slim new tool for 15KHz on normal vga cards
savj14:
Can the Following Resolutions be added:
768 x 240 or 384 x 240 (Street Fighter Series)
384x224
800 x 254 or 400 x 254 = (MK Series)
512 x 448 = (Virtua Fighter)
I tried to read up about adding custom resolutions, but it wan't it English........Does anyone have a quick and easy tutorial on this??
SailorSat:
For CPS games use 392x240, for Mortal Kombat use 401x256, and Virtual Fighter uses 512x384 (which is 25kHz) so you need to use 512x448.
MAME ignores the few extra pixels if you use "video ddraw".
savj14:
--- Quote from: SailorSat on November 26, 2007, 01:17:23 pm ---For CPS games use 392x240, for Mortal Kombat use 401x256, and Virtual Fighter uses 512x384 (which is 25kHz) so you need to use 512x448.
I have been using Power Strip before trying Soft-15KHz and have been using the following resolutions:
Street Fighter Series - 768 x 240
MK Series - 800 x 254
Would the resolutions you suggested be better to use than what I listed above?? In terms of picture quality/Filling the entire screen.
savj14:
Also, If I can add 384 x 240 would that be a better resolution than 392x240?? If that is possible.
SailorSat:
You won't have those tiny black borders left and right, but thats all difference.
