Author Topic: 25" tri sync?  (Read 1807 times)
scurvy
  • Last login:July 23, 2008, 11:31:43 pm
25" tri sync?
« on: May 05, 2007, 07:50:47 pm »
does anyone make one?
i need a monitor to go in a ms. pac man cabinet and its measures the same width as the 27" betson so i dont think it will fit.
looking for a 25" tri sync
Ken Layton
  • Guru
  • Technician
Re: 25" tri sync?
« Reply #1 on: May 05, 2007, 08:09:03 pm »
25" has been replaced with 24.8"
Nieman Displays has 24.8" tri-sync.
A Ms.pac cabinet was supplied with a 19" monitor.
scurvy
Re: 25" tri sync?
« Reply #2 on: May 05, 2007, 08:30:01 pm »
is neiman the only one that carries that size?
do you know how much it goes for?
should fit in the ms pac man
« Last Edit: May 06, 2007, 12:31:43 am by scurvy »
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
Re: 25" tri sync?
« Reply #3 on: May 06, 2007, 10:09:24 am »
You Can get the dimensions you need from our website www.niemandisplays.com go to our products, then CRT products then click the dimension box.
You could reduce the depth by about an inch by cutting the vertical brackets if needed?
Rick Nieman
Rick@Niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
