Main > Main Forum
Does anyone sell Tron Joystick Handles?
Pages: << < (2/4) > >>
Wienerdog:
I'm trying to replace the handle on the joystick pictured below.  It is a Xenophobe joystick on a Tron CP.  I'd like to use this 8way leaf stick on my new CP, so I need to get a new handle.
I plan to try rotating the restrictor plates to get the authentic Tron physical restriction, but I have some research to do.
shmokes:
Happ sells a Heavy Duty 8-way trigger joystick  that won't be right, but it looks somewhat similar and might work.
$100, though  :-\
OSCAR:
--- Quote from: Wienerdog on April 16, 2003, 09:33:13 am ---Oscar referenced Arcade Renovations in another thread, but I didn't see anything there.
They were going to do some repro's, but the deal fell through.  A few BYOAC'rs pre-ordered but then had their $$ refunded later.
Frostillicus:
You can buy just the pieces of the joystick you want on happs site.  just plug in the part# in the search box.  You don't have to spend 100 bucks on a new joystick. I bought some pieces from their heavy-duty 8-way stick and they fit perfectly inside my tron stick shell. - i think it's the same handle design, the bases are different.
Wienerdog:
Cool, that's what I needed to hear.  I really only need (hopefully) the trigger button and the two handle shells.  I have the shaft and the full base.
Go to full version
