Main > Main Forum
Does anyone sell Tron Joystick Handles?
Pages: << < (3/4) > >>
Frostillicus:
yeah just look at their breakaway views for part numbers and type those in - I didn't even know you could do that until I emailed them with my problem.
Brax:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3218897438&category=13718
kspiff:
I'm not sure if it would fit, really, but if you just need the trigger stick replacement grips then I would go through www.therealbobroberts.com, btw.. several dollars cheaper..
planetjay:
--- Quote from: spidermonkey on April 16, 2003, 01:15:45 am ---Xenophobe  Bally/Midway  1987     Unfortunately it won't be a very good stick for playing Tron. :-\
Why not? They are the same stick. 2 buttons were added and the color was changed. it is the perfect Tron replacement if you don't care about color and the ability to be lit with UV.
Another nice thing about his Tron CP with Xenophobe grip is that he can play Mad Planets which uses the trigger and 1 button on the back as well as the spinner.
Wienerdog:
--- Quote from: planetjay on April 19, 2003, 02:25:36 pm ---Another nice thing about his Tron CP with Xenophobe grip is that he can play Mad Planets which uses the trigger and 1 button on the back as well as the spinner.
Spidermonkey,
When you say it won't be a very good stick for Tron, do you mean it won't be as good as an authentic Tron stick, or do you mean it won't be as good as a p360?  It seems to me that the Xenophobe stick is the BEST alternative when an original Tron stick cannot be found.
Planetjay,
The restrictor plate on the original Tron stick is in a diamond pattern, while Xenophobe (mine) is in a square.  Good point about the button though.  It is also needed for Discs of Tron (which I just realized yesterday).  Hmm, does anyone know if the DOT joystick is the same as the original Tron joystick?
kspiff,
Where should I be looking at Bob Roberts site?  The only handle assemblies I see are more expensive.
Go to full version
