Main > Main Forum
metal cutting,HOW ? + simple t-molding question.
OSCAR:
--- Quote from: SNAAAKE on April 12, 2003, 04:54:16 pm ---Thanks for the reply :).
I was wondering if you actually did cut metal using jigsaw?
Did ya?
Just wanna make sure...
Brax,I dont know about handsaw...really works..?
I will go to home depot now and buy both hand saw and metal cutting jigsaw blade to see which works for me.
Yes, of course. Many times. In fact, that's pretty much all I use my jigsaw for. See the piano hinge here, http://www.skum.org/bartop/finish.htm, I cut that one with my jigsaw.
Brax:
--- Quote from: OSCAR on April 12, 2003, 03:19:16 pm ---With a metal cutting blade, a jigsaw will work perfect. Don't use a wood blade, though, or it will be a rough way to go. A metal cutting blade will be somewhere around 32TPI, I think. Mine isn't handy at the moment, but I'm sure someone else can say for sure.
Did ya?
HACKsaw. Yup, it will work. A piano hinge is practically tin. It'll cut through it like butter. Either will work fine.
