Main > Main Forum
Silly wiring question
Carsten Carlos:
Just get a good tool to crimp and strip wires (all in one), and everything goes much easier! :)
Justin:
Is it possible to use quick disconnects to connect all the 'ground' terminals of buttons/joys? I only see how you can make a connection between 2, but then youre screwed. no?
aj6500:
No, just put 2 wires into 1 connector to form a chain.
Smittydc:
Get one of those nice spring-loaded automatic wire strippers -- makes a world of difference... saved my hands a lot of pain.
Then all you have to do is mash the connectors on with the crimper -- which I think is actually kind of fun -- I like the crunching sound it makes. ;D
s8n:
this pic helped me a TON when i was wiring my first CP.
http://www.darkravenwind.com/cdvision/madcatz2.htm
