Main > Main Forum
light up translucent trackball
ampapa2:
I used a Blue translucent ball and backlit it with a flourescent bulb with a 12 volt relay to switch my arcade on. If you're interestedhere is a link: http://ajmmame.webajm.com/
ampapa, :D
Vesper:
The way you're supposed to light these up is with a single 12V bulb. There is a light-assembly that screws into the bottom of the trackball that takes a bulb. You can then just run 12V from a PC molex connector. Looks fantastic and you don't have to mount an entire flourescent down there.
I don't think Happ has these assemblies on their site anymore though. Bob Roberts carries them though. They're cheap.
- Mike
AX:
I wanted a clear ball but they want twice the price for a clear one so... I ordered a clear acrylic 3" juggling ball. When I get it I will let you know if this actually works.
PCC:
EPCO has some interesting specialty balls; although I can't imagine that they are inexpensive.
AX:
this is where i got the ball from.
http://www.extremespin.com/juggling.html
