Main > Main Forum
light up translucent trackball
Pages: << < (3/6) > >>
AlanS17:
Well it's a matter of physics. The density of the ball in this situation is almost negligible as far as speed is concerned because even the heavier ball will reach its maximum speed in a spin. Even the heavier one is light to enough to machieve max spin. (Though it may be easier to spin the lighter one anyways.)
However, the heavier one will achieve greater momentum and therefore keep spinning longer after you release. (Newtonian physics.)
GSXRMovistar:
Whilst on the subject of lighting trackballs I also want to light my 3inch translucent (Blue) Happs ball. I
Carsten Carlos:
--- Quote ---I&#8217;ve found these LEDs at a local branch of Maplin, and wondered if anyone would be able to tell me how many of these I would need for lighting the TB successfully.
Part no.: L-53MBD
IF: 20mA
Light output: 40mcd
How many? Of the one above? Well, twenty, thirty?
Maybe you should get a BRIGHT LED-type!  ;)
Bright LED's have usually 2000mcd and more. (also depending on the color you choose) You don't wanna use a 40mcd-LED for lighting anything up.
GSXRMovistar:
These were the ones they had titled as High Brightness!, They do have some brighter ones ~2000mcd but not in blue  :(
Anyone know where I could get these in the UK?
Thanks.
Carsten Carlos:
I got 2000mcd blue LED's from a mailorder here in Germany. Other colors go even higher! I'm pretty sure there must be some kind of electronic mailorder in UK, too - just search the web for it.  :)
Go to full version
