Main > Main Forum
Do these 4-way sticks mount in 3/4"?
Pages: << < (2/3) > >>
Cue-Ball:
Has anyone ever tried mounting these from ABOVE the CP?  You know, just route out a square the same size and depth as the sticks base, then mount it from above?  Seems like this would be super easy to do and would give great results.  I'm considering doing this myself but was hoping someone else already played guinea pig.  ;D
kspiff:
Someone probably has tried this before, but I wouldn't.. if you plan to put art over your control panel, you'll have to make a choice between not covering the joystick base and never removing your joystick :P
Cue-Ball:
I don't see any reason for that to be the case.  If you can remove the lexan covering the CP, you can remove the overlay graphics since they would be exactly the same (same hole positions and cutouts).
kspiff:
That would depend on whether or not you adhesive the art or just lay it on, I guess.. hadn't occurred to me since I plan to adhesive mine.
Also, though, you'd have to be OK with removing pretty much everything to get the 4-way stick out (should the need arise)..
But I don't get it.. and seriously, here.. how is it in any way easier to route above the CP than below it..?  Or is joystick height the main concern there..?
Magnet_Eye:
wtf kspiff! wHY DO YOU HAVE SUCH A BIG AVATAR IMAGE?
Go to full version
