Main > Main Forum
Do these 4-way sticks mount in 3/4"?
Pages: << < (3/3)
kspiff:
Yeah, this avatar is kinda big.. but at least it isn't wide so I have to scroll horizontally to read some msgs..
It was one of the default selectable ones here @ arcadecontrols, though.. and as to why, well.. Protoman rules.. they should make a Megaman game with just Zero and Protoman 8)
Cue-Ball:
--- Quote from: kspiff on April 05, 2003, 03:50:55 am ---But I don't get it.. and seriously, here.. how is it in any way easier to route above the CP than below it..?  Or is joystick height the main concern there..?
It's not an issue of ease, it's purely an issue of joystick height.  Mounting the stick from the top gives you 1/2" more stick height which many people prefer.  And, of course, if the stick is designed to go under a thin metal CP, then you'd definitely need to mount on the top if using wood just to keep the "stock" stick height.
GearHead:
It's not cheap but you could buy the Pac Man mounting plate for the joystick or make your own.  Top mount the plate using a router and then mount the joystick from underneath. You get the right height and accessibility.
Pages: << < (3/3)
Go to full version
