Main > Main Forum
J-stik shaft diameter
Pages: << < (2/3) > >>
RetroBorg:
I will definately be trying the raider pro hack with an E-stick.
8-way Discs of Tron, 4-way Tron, way to go!
Wienerdog:
The Tron stick has been talked about before.  Isn't it an 8 way stick?  I seem to remember one of the big dogs on this board taking apart his Tron stick to explain how it was build.
RetroBorg:
Perhaps that might be right but I thought you needed a 4-way joystick for Tron especially during the light-cycles. Can anyone else shed some light on this?
kspiff:
I think it was an 8-way trigger stick with a diamond shaped actuator.. that way the primary directions are defined and the corners are available but less reliable and with a smaller 'sweet spot.'
I would just use the J-stick anyways.. short of buying real Tron sticks you'll find yourself out of luck, otherwise (and, hey, why not set up dual Js in 4-way for some Assault action? ;D).
RetroBorg:
You most certainly love your Assualt kspiff, I played it the other day for the first time, not a bad game at all, but I need to try it with 2 x 4-ways.
Go to full version
