Main > Main Forum
Control Panel Database: Post a picture of your Control Panel!
copyimitation:
How do you go about installing cpo art that has designs around the buttons and joystick like you have? I am making my cpo design and i have art around mine as well but was wondering how to line it up with my control panel. Any help?
Happ Perfect 360 Joysticks
Ultimarc GoldLeaf pushbuttons
Ultimarc 3" UTrak Trackball
SlikStik Tornado Spinner
IPac2
Vidiot:
--- Quote from: copyimitation on June 26, 2015, 07:10:34 pm ---How do you go about installing cpo art that has designs around the buttons and joystick like you have? I am making my cpo design and i have art around mine as well but was wondering how to line it up with my control panel. Any help?
I use Paint shop pro to make my art. I just designed everything as actual size then I would print a low quality greyscale version at actual size to see how everything lines up. You might have to print on a couple pages and stitch it together with tape. Button holes are 1 1/8" in size. You will probably have to play around quite a bit until you have something you like.
Took me forever to get it the way I wanted it.
EMDB:
You should first design and print the CPO and use a copy as a template to drill the holes for the buttons and joysticks...
gingerone:
Here's a photo of my recent attempt, be nice :)
Sent from my HTC One_M8 using Tapatalk
megamoze:
Here's mine. Doesn't work yet, but it's pretty much built except for the t-molding.
