Main > Main Forum
Control Panel Database: Post a picture of your Control Panel!
dylaninwv:
My turn for gratuitous CP pics....
Mine is coming along. Cab is a space-themed one - bezel is going to end up being the old archway from Space Port - since Space Port is where I shoveled my quarters out by the pound...
Still have to put the T-moulding on, and wire the two mouse buttons, but almost done. The post to the right of the mouse buttons is a USB volume control - just have to add the knob. eventiually I plan to add an extension to the bottom front to hold a flightstick, to resemble the center placement of a flightstick from a cockpit - but that's down the line.
rabidpuppy:
Super-Pro™ Leaf Switch 8-way Arcade Joystick
Versa-Ball 2™ Multi-Compatible Ball-Top Joystick Shafts
CLASSX™ Colors - BLUE - Leaf Switch Compatible Button - Switch Type: True-Leaf Pro™
Micro-Leaf™ Arcade Pushbutton Switches
(P3 & P4 are Zippyys but using universal mounting plates)
7" Doublesight USB monitor
iPac4
More pics here but nothing groundbreaking in this build. https://flic.kr/s/aHskdxuYPW
[url=https://flic.kr/p/umeBpM]
Vidiot:
Happ Perfect 360 Joysticks
Ultimarc GoldLeaf pushbuttons
Ultimarc 3" UTrak Trackball
SlikStik Tornado Spinner
IPac2
MydknyteStyrm:
MCP Control Panel
Four Ultrastik 360s
UTrak trackball with LEDs
TurboTwist spinner
UltraLux RGB Buttons
Buttons for flippers and plunger as well.
copyimitation:
Here is my setup. I used a template i found online for Visio, and edited it to my liking. I took this to Staples and had them print me out a blueprint for about $4.
