Author Topic: T-Molding  (Read 3550 times)
gajaman
  • Last login:July 19, 2011, 02:50:33 pm
  • The GajaCab is here......
    • The Gaja Project
T-Molding
« on: April 04, 2002, 09:52:14 am »
I've received my order of T-molding from happs and am surprised how small the bottom part of the T is.
The width of the bottom is only about 1.5 - 2mm and I can't find a slot cutting router bit small anywhere near small enough. The best supplier in the UK I could find on-line is www.trendmachinery.co.uk/profinder/ but they don't do anything below 3mm.
Any advice?
« Last Edit: December 31, 1969, 07:00:00 pm by 1026619200 »
darkmanx
  • Last login:May 29, 2003, 04:46:57 am
  • I want to Build My Own Arcade Controls!!
Re: T-Molding
« Reply #1 on: April 04, 2002, 11:13:08 am »
alot of people use cutting or grinding discs in a dremel tool or similar tool. i used a router bit and its too big but dont worry...hot glue will hold it in place perfect if you go that route. either way works fine.
WHELP! As if you knew what an eternity was. Grovel before your true master!
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
darkmanx
Re: T-Molding
« Reply #3 on: April 04, 2002, 11:38:41 am »
$31.00.....ouch
JustMichael
  • Mmmmm!! Cheesecake!!
Re: T-Molding
« Reply #4 on: April 04, 2002, 11:52:16 am »
Less ouch: http://www.routerbits.com/cgi-routerbits/sr.cgi?968180030_22805+105
I saw this link quite a while ago and saved it for when I build a cab from scratch.
darkmanx
Re: T-Molding
« Reply #5 on: April 04, 2002, 12:21:03 pm »
not as bad but notice they are 2 piece. you need to buy the arbor and the blade  :-/
ddebuss
  • Last login:January 20, 2015, 07:48:10 am
  • Stuck in the 80's
Re: T-Molding
« Reply #6 on: April 04, 2002, 03:56:39 pm »
If the slot that is cut is too deep.  There are two options:
1. Ignore it.  It fits just the same
2. Use a larger bearing.  It won't cut the slot as deep.
Lookup woodworking in the phone book.  Take a piece of t-molding with you.  They will sell you the cutter, the arbor, and the bearing.  I recall the price as reasonable, but couldn't remember what the total was.  Definately a lot less than the $31 that t-molding.com wants for just the cutter without the arbor and bearing.
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
Re: T-Molding
« Reply #7 on: April 05, 2002, 06:15:20 pm »
This is what I'm doing:
I have a smaller handheld radial saw where I can set the depth on it.  I can also attach a guide that will allow me to cut the groove right in the center of the wood.  So as long as you set your depth to fit your molding, you are set.
Jakobud
