Main > Main Forum
Which ones do YOU prefer?
Pages: << < (8/8)
Wienerdog:
--- Quote from: kspiff on March 22, 2003, 02:09:28 am ---I don't think anyone has tried it, though, and I would probably sooner just buy a J-Stick than a competition/P360 + replacement handle + restrictor (if desired)..
I probably agree, but at $25 for a P360, it is close enough for me to think about it.  I really don't like microswitch joysticks.
telengard:
--- Quote from: Amra on March 16, 2003, 03:26:01 am ---The question is, which joystick do you use, which would you prefer, what if money were no object, and lastly...
Why?
I only use leaf joysticks, which weren't mentioned in your
list.  For me there is no comparing them to microswitch joysticks.
I've also tried the Perfect 360s, I personally don't like them either.
I also tried the Perfect 360 "add on" for my WICO leafs, didn't
like those either.
If you are into the "old school" games, a leaf is the way to go.
The newer games, from what I've read in here, seem to be mostly
microswitch.  Your best bet is to try them both and see what you like.
Amra:
--- Quote ---I've also tried the Perfect 360s, I personally don't like them either.
What did you NOT like about them?
I emailed happs, they said the P360's are nothing like the Supers, so chances are, the Modified Super rumer is nothing but just that, a rumor.
As for Leaf Switches, I didnt include them because I personally do not plan on using one, though I like them for perticular games, like Pac Man, those arent the games I will be playing the most, so I decided to pass them up for something that works good not ONLY in those types of games, but in Fighters as well.
I will give a detailed layout of the design when I get them, which should be next week some time.
Edit:  Almost forgot, Ill be putting up pictures of teh Joystick next week too, i.e. Connections, and etc.  There seems to be a lack of knowledge about these joysticks.
jdjuggler:
Does anyone know if the spring tension on the P360's  is similar to the supers?   And, if it much stiffer, can they be adjusted?
Thanks.
Pages: << < (8/8)
Go to full version
