Main > Main Forum
Which ones do YOU prefer?
jdjuggler:
I was curious about the "spring?" tension on the P360's. I'd like to compare the spring tension to that of the Super's. I'm trying to decide between the two.
I've also heard that the P360's are the ones used in NFL Blitz? True? Thanks.
Amra:
Ive ordered my P360's, Ill give you the 411 when they Get here and I can test them :)
jets:
happ p360s all the way.
Wienerdog:
Is there a ball top that you can put on a p360? I'm considering dedicating one as a 4way with a restrictor plate. Otherwise I'll go with a ball top J-Stick.
kspiff:
I think that has been discussed before.. it was commented that those sticks will work with competition and super joys and that the P360 is a modified Super..
I don't think anyone has tried it, though, and I would probably sooner just buy a J-Stick than a competition/P360 + replacement handle + restrictor (if desired)..
