Author Topic: Echo...echo...echo  (Read 2947 times)
gamecreature
  • Last login:October 29, 2008, 08:35:37 pm
  • I'm making this up as I go along.
    • Gamecreature
Echo...echo...echo
« on: June 25, 2006, 08:15:21 pm »
For some reason, Mame is echoing on this old system I have it set up on. It's trying to play all of the sounds twice. I have a feeling that some parameter or other is messed up, but I don't know where to begin. Any ideas?
Make your cabinet look its best with custom art from
Gamecreature!
lcddream
  • Last login:December 04, 2024, 03:59:31 pm
  • Say goodbye to gravity...
Re: Echo...echo...echo
« Reply #1 on: June 25, 2006, 08:36:28 pm »
sounds like a potential audio driver issue. find the most current driver for your audio hardware uninstall the currrent and install the new.
Buddabing
« Reply #2 on: June 25, 2006, 08:47:46 pm »
Do you have -wavwrite set?
Please read the wiki!
TOK
  • The Game Always Wins
« Reply #3 on: June 25, 2006, 09:04:23 pm »
Are the games playing slightly slow? This is a classic symptom of a PC that's too slow for the version of MAME you're running.
gamecreature
    • Gamecreature
« Reply #4 on: June 25, 2006, 10:48:39 pm »
No, I don't think I have wavwrite set. Some games are running slow, some are running just fine. On the slow ones, the sound always seems to stutter.
Gamecreature!
loadman
    • MaLa
« Reply #5 on: June 25, 2006, 11:41:13 pm »
Yep,
 jump down to a much earlier version of mame and see if you have the same problem
PS...
You are running Win ME right (YUK x 10000000000000) I would jump backwards and use 98SE before I used that.
Anyway.....and other than that what are you using:
What Processor?
Memory?
Mame version?
« Last Edit: June 25, 2006, 11:44:05 pm by loadman »
gamecreature
    • Gamecreature
« Reply #6 on: June 26, 2006, 09:33:35 am »
Yep,
PS...
What Processor?
Memory?
Mame version?
If I can get my hands on an earlier version, I will. Seems that all I have are old versions of Mame32...
Here's the breakdown:
OS: Win ME (ME, XP and 95 are my only choices right now)
Mame: Mame32 v104, running through MaLa.
Memory: I'll have to check - let's call it 128 megs to be safe.
CPU: Intel Pentium 300 Mhz.
ATI Rage graphics card.
Soundblaster sound card (have to check to see what kind)
Dell motherboard
I'm going to turn off the sounds on MaLa to see if that makes a difference.
Oddly enough, I expereinced an identical problem with Mame32 v.104 on a 1gig machine, but I don't remember how I finally managed to fix it.
Gamecreature!
« Reply #7 on: June 26, 2006, 09:46:51 am »
Some things to try:
command line version of mame
Mame32 not using mala
Sounds to me like the machine may not be totally up to snuff. I used a p2350 and had nothing but problems with it. Multiple key presses caused beeping, sounds not playing right, etc. I "fixed" the problem with a different computer.
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #8 on: June 26, 2006, 09:58:53 am »
There's your problem right there.  Find some lower CPU intensive games like Pac-Man.
gamecreature
    • Gamecreature
« Reply #9 on: June 26, 2006, 10:05:13 am »
Or Space Invaders? Cause I'm getting the double sounds in there, too. Robotron, on the other hand, plays just fine. I'm boggled.
Seriously, I'm due to get a faster machine (a freebie) but I can't get a straight answer on when it will arrive.
Gamecreature!
loadman
    • MaLa
« Reply #10 on: June 26, 2006, 06:55:17 pm »
All the old versions can be found here:
http://www.mame.net/oldmame.html
Read the text at the top of the page as there isn't links for all versions. But all versions are kept at that site its just a case of http://www.mame.net/zips/mame???b.zip replace the questions marks with the old version you want.  eg 087
« Last Edit: June 26, 2006, 06:56:48 pm by loadman »
gamecreature
    • Gamecreature
« Reply #11 on: June 26, 2006, 10:35:57 pm »
Thanks. Downgrading to 087 speeds things up a lot. I just need to figure out how to hide mame's DOS window when it starts the game and I'll be set!
Gamecreature!
loadman
    • MaLa
« Reply #12 on: June 26, 2006, 11:11:20 pm »
Funny, Everyone misses that step even though its in help   ;)
Change window state to 'hidden' in MaLa
gamecreature
    • Gamecreature
« Reply #13 on: June 26, 2006, 11:41:55 pm »
D'oh!  I went past that page 30 times. Oh well, thanks again. My cabinet lives!
Gamecreature!
SirPeale
« Reply #14 on: June 27, 2006, 12:36:45 am »
Or Space Invaders?
Betcha got artwork enabled.  Turn it off and tell me how it's playing.
Robotron doesn't take much horsepower, I don't know why.  I've got all the Williams classics running on my horizontal cab.  All that has is an AMD 450.
