Author Topic: Dead Motherboard??? What do you guys think????  (Read 1808 times)
koolmoecraig
    • My Intervention
« on: May 31, 2006, 02:18:54 pm »
I had my Rally-X machine going, I left the room and came back to find the screen had gone blank. It was still on but nothing I did made any sounds.
I tried to reboot. The machine turns on and the hard drive spins for a tiny bit but nothing loads.
I tried clearing the CMOS, no difference.
I tried two different video cards with no difference..
I hooked the hard drive up to my computer and I can access it just fine.
I am leaning towards the motherboard being bad. It's one of those ECS pieces of crap so I wouldn't b surprised.
brained
  • Last login:May 24, 2026, 09:06:19 pm
  • Raised by Atari
    • Nux
Re: Dead Motherboard??? What do you guys think????
« Reply #1 on: May 31, 2006, 02:31:25 pm »
did you check the memory? sometimes you just need to reseat the memory ;)
Mr Ironpants
  • Last login:October 14, 2009, 02:14:44 am
  • Take off to the Great White North
« Reply #2 on: May 31, 2006, 02:40:47 pm »
Sounds like you are right.  Just a few questions I would ask if you were on the other end of the phone.  Yes I used to do this day after day after day after day....
Does the machine go through a the Post test and produce any beeps?  There is a slight possibility that it could be memory but I doubt it.  Generally if it is memory the machine will try to iterate the memory and then give the audio warning beeps (don't remember what they are its been awhile since my A+ test).
Does the drive spins for like a second and then stop?
Are you getting anything at all on the screen when you boot?  It sounds like you are since you cleared the CMOS but I want to make sure (unless you are doing the old crossing the jumpers trick or whatever the manual reset is on this motherboard)
Also, and this falls in the line of is it plugged in so please ignore if appropriate, have you tried the monitor on another box?
Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life. - Terry Pratchett
koolmoecraig
    • My Intervention
« Reply #3 on: May 31, 2006, 02:55:10 pm »
I reseated the memory with no effect.
The machine makes no beeps at all. I get nothing on the screen.
I have an arcade monitor so I haven't hooked it to anything else, but the machine doesn't load at all. Even if the monitor was bad it would play blind which it doesn't.
The hard drive stays spinning but there are no "accessing noises" coming from the drive. The only way I know it is spinning is by holding it in my hand and feeling it.
All that happens when I turn it on is the drive starts spinning the CPU fan turns on and that is it.
I'm off to buy another motherboard to see if that is it. I'll let you know.
Thanks for the input. Keep it coming if you have any other ideas.
One more question? Why does this crap always happen right before you're going to have a friend in from out of town or a party?
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #4 on: May 31, 2006, 03:36:29 pm »
Did you try another power supply?
Tis the season!
(I've replaced about 20 power supplies in the last month.)
And around 10 motherboards..
Later,
dabone
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« Reply #5 on: May 31, 2006, 04:34:58 pm »
2nd on the power supply check it before you buy anything
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
« Reply #6 on: June 01, 2006, 03:07:57 pm »
Another vote for checking the PSU
Mamezilla
  • Last login:March 04, 2026, 03:11:36 pm
« Reply #7 on: June 01, 2006, 10:19:52 pm »
I've got a friend's computer that I'm trying to repair and it does exactly the same thing.  All the fans and the hard drive spins, but nothing gets on the screen.  No POST beeps at all.
If something was wrong with the PSU, could the fans and hard drive spin anyway ?  I know there is voltage coming out of it, I've checked one of it's HD connectors with a voltmeter and there is 5 and 12 volts on it.
Don't throw rocks to a man with a machine gun
-- Rowdy Roddy Piper --
divemaster127
« Reply #8 on: June 01, 2006, 10:26:15 pm »
sure you can still have fans etc, your power supply is no longer putting the correct voltage, i would check it away
dm
« Reply #9 on: June 01, 2006, 10:28:54 pm »
I've had cards cause shorts which exhibited this same issue. One thing to always do is bring the system down to a basic level by removing everything except the essentials. Pull the power to everything but the mobo, remove all cards except video, pull all but 1 stick of memory, pull the mouse/keyboard connections and see if it'll post.
davieboynj
  • Last login:June 16, 2011, 01:32:09 am
  • Eating your legs solves lifes little problems.
« Reply #10 on: June 02, 2006, 10:07:30 am »
95% of the time its a power supply.  the question is, what else did the power supply take down with it...
krick
  • Gotta have blue hair.
« Reply #11 on: June 02, 2006, 12:43:00 pm »
Speaking of power supplies, there's a new power supply issue that has started appearing recently.  It obviously isn't what is going on with the original poster's machine but I thought it was relevant in light of the recent posts.
If you have a new high-efficiency power supply, combined with system that doesn't draw much power (usually mATX with integrated video, and often using an AMD CPU), when you turn on the sytem, the fans spin but it won't POST.  More info...
http://forums.silentpcreview.com/viewtopic.php?t=30289
I'm helping a friend build a sytem that has this problem.  I'm making a load resistor for the 12V line that pugs into a spare drive power connector that should hopefully fix the problem.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
