Author Topic: power plug cabinet mount??  (Read 3557 times)
squirrellydw
« on: March 23, 2006, 10:09:41 am »
Does anyone know where I can get power plug cabinet mount?  I am looking to plug the power supply into one side (the inside) and than the power cord into the other side (outside).  I would like it to be flush mounted if possible.  Also looking for the same thing for network and USB cable.  I know I could use something like a wallplate for that but didn't know if there was something better.
I b**ch. People listen!!
quarterback
Re: power plug cabinet mount??
« Reply #1 on: March 23, 2006, 11:03:29 am »
As far as power, a number of people have used things like this:
[click image for link to product]
As far as USB goes, markvp posted pics of these cool items.  This is a firewire one, but they have USB apparently:
Link to thread
-- Chad Tower
squirrellydw
« Reply #2 on: March 23, 2006, 01:14:54 pm »
dude that is just what I wanted, you rock.  the power plug link is broken but I can find it.
bossyman15
  • Last login:March 05, 2012, 01:35:08 pm
  • I am now building my own arcade controls!
    • Bossyman15 Arcade Pics
« Reply #3 on: March 23, 2006, 02:41:11 pm »
i need that too! but i can't find it on that site
what word do i use to search?
My website: www.bossyman15.com Lots of arcade pictures inside!
quarterback
« Reply #4 on: March 23, 2006, 04:24:05 pm »
I'll find the link for you... actually, I'll try and find the one that I actually bought which also has a built in fuse.
I don't remember where I bought it, but I'm sure I didn't drop much money on it (cuz I'm a tight-wad).  I'll find the receipt later tonight and post here.
-- Chad Tower
quarterback
« Reply #5 on: March 23, 2006, 04:31:20 pm »
Here's the one I bought.  It was $4.95 but they have a cheaper one as well.  Herbach & Rademan calls them "Power entry" modules, so that might help if you're Googling.
http://www.herbach.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=HAR&Product_Code=TM02SWH4578
-- Chad Tower
squirrellydw
« Reply #6 on: March 23, 2006, 05:51:28 pm »
are you happy with this one?  Do you just hit the switch and have everything power up?
quarterback
« Reply #7 on: March 23, 2006, 06:44:04 pm »
I still haven't installed it, even though I bought it at the end of 2005.   Too many projects, too little time :)
-- Chad Tower
  • Last login:December 16, 2025, 04:07:15 pm
« Reply #8 on: March 23, 2006, 09:35:31 pm »
I like it, but I think the part I'm having a hard time with is what the other side looks like. I've googled the image, but I can't see how the it connects. I'm no electrician. What I'd like is a standard plug on the other side that I can plug a surge protector into. Is there such a thing?
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« Reply #9 on: March 23, 2006, 10:48:32 pm »
it's four prongs on the back...
it'd be simple enough to hack off the end of the power strip and wire it to the plug...
or...
just wire a wall outlet in a box to the plug...then plug your power strip into that...
if you supply me with the parts & cover shipping...i'll do it for you...!
« Last Edit: March 23, 2006, 10:52:42 pm by fixedpigs »
« Reply #10 on: March 23, 2006, 11:07:15 pm »
or...
Yeah... I've always heard everyone else say how that avatar freaks them out and I never knew what they meant as I stare at it. I swear that spider is moving. Thanks for the offer, but you make it sound simple enough.
4 prongs, hacking off electrical sounds simple enough. I'll give it a shot.
If all of a sudden I quit posting messages...
bossyman15
« Reply #11 on: March 24, 2006, 12:29:41 am »
thanks! but ummm i have old dying PC powersupply sitting on my desk. i wonder if i can just rip out the power pong from it and use it in my cab?
quarterback
« Reply #12 on: March 24, 2006, 12:40:16 am »
I'm sure you can without much problem.  I bought the one I posted earlier because it has a built in on/off switch and is made to be mounted.  It has little clips and 'wings' to overlap the edges of the (assuredly) rough hole I end up tearing in my cab :)
« Last Edit: March 24, 2006, 01:33:36 am by quarterback »
-- Chad Tower
bossyman15
« Reply #13 on: March 24, 2006, 01:30:45 am »
ok i just took apart my power supply and well see the attached picture...
there are whole lot of wires near power pong. but there are also a circit board attached to power pong.
#1 picture shows what inside looks like around PP area.
#2 picture shows the inside and back of PSU so you know which part is which.
#3 picture (blurry) shows the circit board that are attached to PP.
its may be to much trouble for its worth (for me) so I will just drop a few more bucks for one of those.
« Last Edit: March 24, 2006, 01:33:21 am by bossyman15 »
bossyman15
« Reply #14 on: March 24, 2006, 03:19:53 am »
i found this one
very cheap dunno about shipping tho
will this work? (i don't want on/off switch)
http://www.interpower.com/scripts/wsisa.dll/WService=ic/p30form.p?w_part=8301213
edit: oh i found even cheaper one!!! (69 cent!)
https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=147900
how's that one look?
and they both are USA standard right?
« Last Edit: March 24, 2006, 03:57:22 am by bossyman15 »
quarterback
« Reply #15 on: March 24, 2006, 11:41:34 am »
Those both look fine but you could also just rip the one out of your power supply.
These aren't really doing anything but acting as a pass-through for the electricity, so even if there are a bunch of other things attached to the back of the plug in your computer power supply, you don't really need them.    I can't tell from the pics, but in your PS there's probably just some kind of fuse along with some kind of 110/220 regulator or something (since PSs usually have that 110/220v switch on the back) but all you are really needing is the plug itself for its aesthetic look and the ability to plug in/unplug the wire that goes to the wall.
If the PS is really failing and/or just extra parts, I'd just rip the plug out and go from there.
-- Chad Tower
squirrellydw
« Reply #16 on: March 24, 2006, 12:12:29 pm »
I assume this works in the USA and do you know if partsexpress has these?  I can't find any on the site.  Just asking because I am ordering some stuff from them
« Last Edit: March 24, 2006, 03:52:13 pm by squirrellydw »
jcrouse
  • Last login:January 09, 2010, 05:53:51 pm
    • CPViewer
« Reply #17 on: March 24, 2006, 05:30:44 pm »
I usually get theses from Mouser. I think it is www.mouser.com.
John
squirrellydw
« Reply #18 on: March 25, 2006, 06:59:45 pm »
dammit, minimum order is $15
