Author Topic: Mamewah List Generation/Organization?  (Read 1307 times)
Jakobud
  • Last login:Yesterday at 10:09:01 am
« on: July 08, 2005, 06:59:01 pm »
hey guys... so I have been sorta on the sidelines of the arcadecontrols.com scene for quite a while.  But I've recently been messing with the newest Mamewah (never really put it thru it's pace's before).  I'm totally impressed with it and its flexibility in layout management.  There are a few things I would request to improve it, but overall... solid!  My hat's off to Minwah.
My question is, what is the easiest/best way to do some good list organiztion or generation?  I've been using Mamewah Config 1.61.1 to do most of it.  There has to be a better solution than that though... I hope...
ahmer
  • Last login:March 16, 2014, 02:40:21 pm
  • Do as you like.
    • IC Markets Rebates and Discount
Re: Mamewah List Generation/Organization?
« Reply #1 on: July 08, 2005, 08:22:27 pm »
I don't know the best way of generating gamelist in mamewah 1.61 but i can tell you the one which always works for me.
list_generation_method                    rom_folder_vs_listxml
xml2info.exe [This file should be in your mame directory]
Btw,Mamewah 1.61 easily generate gamelist.
2600
« Reply #2 on: July 08, 2005, 08:56:06 pm »
listgen
Do a search for it, but with Buddabing's listgen you can make a list really easily for more FE's then just MAMEWAH.
While you are doing that look up Buddabing's MameMovieMaker, and to squash any fears and incorrect information you may read, you don't have to compile anything.
