Author Topic: Project64 and Mamewah problem  (Read 3802 times)
tapnout
  • Last login:April 17, 2010, 02:09:20 pm
« on: May 31, 2005, 10:53:45 pm »
Everytime i try to open a project64 file it says this "Attempt to open file failed!". Then once i click "OK" it brings me to the project64 screen. If i try to open the file from the project64 screen that opened it works fine. Any ideas? I'm using mamewah 1.5 and the latest version of p64 with the wrapper from the CPVIEWER web page. Thanks.
Dire Radiant
  • Last login:January 23, 2025, 06:30:10 pm
  • Cor, chief!
Re: Project64 and Mamewah problem
« Reply #1 on: May 31, 2005, 11:51:20 pm »
Try to open a game from Mamewah then post the last entry in your mamewah.log file. It should look something like this
5/31/2005 10:45:54 PM MAMEWAH launched
5/31/2005 10:45:54 PM Cursor scheme: Windows default, Arrow: (None), Wait: (None), AppStarting: (None)
5/31/2005 10:45:54 PM Desktop colour: 0
5/31/2005 10:45:54 PM Wallpaper filename:
5/31/2005 10:45:54 PM Display mode: 1280x1024 @ 60Hz, 32 bit colour
5/31/2005 10:45:54 PM Decimal symbol: '.'
5/31/2005 10:45:54 PM Games list read: 0002-1.lst
5/31/2005 10:45:55 PM Layout selected: G:\Emulation\Mamewah\layouts\_installed layouts\0002.lay
5/31/2005 10:45:55 PM Ctrlr file selected: G:\Emulation\Mamewah\ctrlr\default.ini
5/31/2005 10:46:02 PM Layout selected: G:\Emulation\Mamewah\layouts\_installed layouts\0001.lay
5/31/2005 10:46:02 PM Games list read: 0001-1.lst
5/31/2005 10:46:28 PM Commandline run: G:\EMULAT~1\PROJEC~1\PROJEC~2.EXE "d:\roms\n64\BANJO-KAZOOIE (U) [!].zip" {flags=9}
5/31/2005 10:47:45 PM Commandline run: G:\EMULAT~1\PROJEC~1\PROJEC~2.EXE "d:\roms\n64\EXTREME-G XG2 (U) [!].zip" {flags=9}
5/31/2005 10:48:52 PM MAMEWAH quit
tapnout
« Reply #2 on: June 01, 2005, 12:45:43 am »
Here you go:
5/31/2005 7:25:54 PM c:\Sega\Sega.exe "c:\Sega\roms\LETHAL ENFORCERS (U) [!].zip" -fullscreen
5/31/2005 7:27:03 PM c:\Sega\Sega.exe "c:\Sega\roms\VALIS (U) [!].zip" -fullscreen
5/31/2005 7:31:12 PM c:\mame\mame.exe 1943J
5/31/2005 10:27:15 PM c:\zsnes\zsnes.exe c:\zsnes\roms\ADDAMS FAMILY VALUES (U).zip
5/31/2005 10:43:30 PM c:\zsnes\zsnes.exe c:\zsnes\roms\3 NINJAS KICK BACK (U).zip
5/31/2005 10:53:03 PM c:\zsnes\zsnes.exe c:\zsnes\roms\2020 SUPER BASEBALL (U).zip
5/31/2005 11:00:19 PM c:\PROJEC~1\PROJEC~1.EXE "c:\project64\roms\007 - THE WORLD IS NOT ENOUGH (U) [!].zip"
6/1/2005 12:53:45 AM c:\PROJEC~1\PROJEC~1.EXE "c:\project64\roms\007 - THE WORLD IS NOT ENOUGH (U) [!].zip"
Johnny
  • Last login:March 11, 2026, 09:49:03 pm
  • I Want My Own Coctail Cabinet!!
« Reply #3 on: June 01, 2005, 07:23:33 am »
Hi tapnout,
Try to remove the  "(U) [!]" from the filename.
- Johnny
Johnny Andersen
 Oslo - Norway
jcrouse
  • Last login:January 09, 2010, 05:53:51 pm
    • CPViewer
« Reply #4 on: June 01, 2005, 07:58:13 am »
Dire Radiant
  • Cor, chief!
« Reply #5 on: June 01, 2005, 01:05:26 pm »
Looks to me like you have Mamewah pointing at Project64 itself instead of the wrapper - or youre using jcrouse's ini file but didnt download the wrapper at all.
tapnout
« Reply #6 on: June 01, 2005, 01:35:34 pm »
JCrouse Here is my ini file:
### project64.ini ###
emulator_title                            Nintendo 64
### List Generation Settings ###
rom_path                                  c:\project64\roms
rom_extension                             zip
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
emulator_executable                       c:\project64\project64.exe
send_rom_path                             1
send_rom_extension                        1
quotes_around_romnames                    1
long_filenames                            1
show_dos_box                              no
default_options
extra_options_1
extra_options_2
### Artwork Locations ###
artwork_1_image_path                      c:\project64\snap
artwork_2_image_path                      c:\project644\titles
artwork_3_image_path
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               1
saver_type                                slideshow
scr_file
wrapper_executable
wrapper_options
movie_path
### Additional Settings ###
music_path
controls_dat_viewer_executable
controls_dat_viewer_options
auto_launch_controls_dat_viewer           1
ipc_file_or_path
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              1
Dire Radiant : i'm almost sure i'm using the wrapper file also. Let me double check.
tapnout
« Reply #7 on: June 01, 2005, 01:37:13 pm »
JCrouse. Can your ini. file and wrapper be used in mamewah 1.5? i'm using your wrapper but not your ini. file. Also i'm not sure if i'm using the wrapper right. How exactly do you install it?
« Last Edit: June 01, 2005, 01:40:34 pm by tapnout »
jcrouse
    • CPViewer
« Reply #8 on: June 01, 2005, 01:42:26 pm »
INI file = no way!
Wrapper = I'm not sure.  I only use it with Windows XP SP2 and MameWAH 1.61.
Good Luck,
John
tapnout
« Reply #9 on: June 01, 2005, 02:30:26 pm »
So do you think the only way to fix this problem is to update mamewah?
Dire Radiant
  • Cor, chief!
« Reply #10 on: June 01, 2005, 02:35:56 pm »
Updating Mamewah would be a good idea but in any event I dont think you're actually using the wrapper there. You appear to have Mamewah pointing at the project64.exe. You need to point it at Project64Wrapper.exe. Put both the wrapper exe file and cfg file in your Project 64 folder and edit the cfg to reflect your paths. I can't really think of a good reason why the wrapper wouldn't work under Mamewah 1.5. If you change your Mamewah.ini to point at project64wrapper.exe all should be well.
« Last Edit: June 01, 2005, 02:38:27 pm by Dire Radiant »
tapnout
« Reply #11 on: June 01, 2005, 02:52:13 pm »
Ok i never put the cfg files in the project64 folder. Now that i did and set the correct paths, when load a rom all i see is the rom loading screen show for like half a second and then the load screen disappears and goes back to mamewah.
