December 24, 2025, 08:36:22 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Arcade Stuff
through our link. Thank you!
Well, that was weird. Outage sorted out. Thank you SirWoogie for saving the day!
Main
Main Forum
Ultimate Noob Question (Joysticks)
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Ultimate Noob Question (Joysticks) (Read 1215 times)
CPickler
Trade Count:
0
Full Member
Offline
Last login:August 20, 2006, 02:37:14 am
I want to build my own arcade controls!
on:
April 15, 2005, 07:01:03 am »
I have the Happ controls Super Joysticks.
How are they supposed to be mounted?
Is the long side supposed to be parallel to the monitor or perpendicular?
I probably should have asked this before I drilled the first one.
Also, is there a side that needs to be facing towards the monitor and if so how can you tell?
By the way, if I screwed this up by drilling so that the long side would be parallel with the monitor would wood filler work to fill in the 4 1/4" x 5/8" deep holes?
Logged
paigeoliver
Trade Count:
+2
Full Member
Offline
Last login:July 06, 2024, 08:43:49 pm
Awesome face!
Re: Ultimate Noob Question (Joysticks)
Reply #1 on:
April 15, 2005, 07:03:45 am »
It doesn't matter at all. You can face them which ever way you want (of the four primary directions).
Logged
CPickler
Trade Count:
0
Full Member
Offline
Reply #2 on:
April 15, 2005, 07:11:16 am »
is there any advantage to any of the mounting directions?
Logged
teef two
Trade Count:
0
Full Member
Offline
Last login:November 24, 2006, 08:21:45 am
Mmmmame
Reply #3 on:
April 15, 2005, 07:11:31 am »
Thinking logically certainly helps when putting all the bits together
You have four micro-switches, each of which corresponds to a direction that's inverse to the way the joystick is moved (i.e. Move the joystick left and the right hand side switch will be operated.)
So as long as you wire it up correctly it doesn't matter which way you mount it. Just thought I'd explain why in case you didn't realise.
Personally I mounted mine vertically as it gave me more room for button mounting as I was pushed for space.
Logged
CPickler
Trade Count:
0
Full Member
Offline
Reply #4 on:
April 15, 2005, 07:13:46 am »
yeah, after I made the post I started thinking about it. I was working on my first final version of my CP and been working on it since 11 PM and am obviously not thinking well.
Logged
paigeoliver
Trade Count:
+2
Full Member
Offline
Awesome face!
Reply #5 on:
April 15, 2005, 07:14:54 am »
No advantage at all, some games had them some way, some games the other way. I usually mount them vertical, but it doesn't really matter.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Main Forum
