Main > Project Announcements
Arcade Bones (Marquee & Dashboard graphics finalised)
Pages: << < (112/135) > >>
Bones:
The horrid job done on yesterday
Bones:
I felt this idea might work so today I went to a picture framing shop that sold cardboard. I selected a piece of 2mm cardboard that was white on one side and black on the other.
I got home and transferred a corner design to the new material and ran some tests on how well it would bend, I discovered that to get a clean fold that would not pull the black layer off the cardboard, I needed to score the edge that was on the opposite side of the fold. As this material was much thicker than my trial pieces I also had to make some adjustments to accommodate the extra width.
I made several more templates before getting a result I was happy with.
Bones:
Once the 4 pieces were cut out I was ready to assemble.
Bones:
I put it together and temporally fixed the folds with some masking tape and checked it for size. It was pretty close and only a small trim was required on the sides to tidy it up.
I then proceeded to use a hot glue gun to fix the folds into place. Each corner I did stiffened the whole assembly.
This pic is of the back which shows how the folds fit the design.
Bones:
And finally a few pics of the finished bezel. The cardboard cost $12.00 and I already had everything else needed (ruler, knife, scissors & glue gun). I may get a black marker and dark the white cut marks although I kind of like the way they frame the monitor area so will probably leave it.
From start to finish it took quite some time, probably about 4 hours. I found it very difficult to photograph, to the naked eye the entire section is pretty much invisible under the tinted glass as I suspected
Go to full version
