Main > Everything Else
OK DON'T ...Ignor this post!!!
Pages: << < (2/4) > >>
DrewKaree:
--- Quote from: 1hookedspacecadet on April 01, 2005, 12:32:12 am ---You need to drag and drop the picture you want from your hard drive to the red "x" under your post.  Do it on one post, then refresh the page and it should show up in all your posts.  It can be tricky to line up so repeat if it doesn't work the first time.
If you don't see the red "x", you'll probably have to download and install the latest update to your browser.  If that doesn't solve it, you probably don't have .NET on your PC.  Windows XP usually installs this, so try a fresh install.
If you can't line it up correctly, make sure your screen resolution is set to 1100x547.
JDSkydiver:
OK...
So I have under the Signature section of my profile...
And I hit Change Profile....
But when I view the Post, I see a "depressed box/button with a RED X in it.
I can't seem to drag & Drop the image to the post.  Can others see the Signature Image?
I know the URL works cuz' I put the ardess in the browser window and it comes up.
HELP!!!
Thanks again guys, I really appreciate the help!
Shape D.:
--- Quote from: cholin on March 31, 2005, 07:20:50 pm ---Umm okay?  Go into your profile, then use the IMG tag [img ]URL HERE[/img ]
example
[img#]http://forum.arcadecontrols.com/index.php?action=dlattach;id=11375;type=avatar[/img*]
that will bring your avatar into your sig
remove the  # though.
check my sig.
JDSkydiver:
I don't want my avtar, but a different image that's hosted...
Using your # and * example, here's what I have...
[img#]http://www.www.pebblecanyonhoa.com/marque.jpg[/img*]
(but without the # and * of course)
All that shows up is the BOX with that dreaded RED X.
Am I doing something wrong?
Thanks again...
JoyMonkey:
Ehhh.... could be your double www in the url. Just a guess  ;)
--- Code: ---[img]http://www.pebblecanyonhoa.com/marque.jpg[/img]
--- End code ---
Go to full version
