Main > Everything Else
OK DON'T ...Ignor this post!!!
DrewKaree:
If your system isn't too screwed up and you can get to a command prompt, formatting your hard drive should solve things, and once you're back up, you should have no problems with this.
If a format doesn't solve it, you may have a bad power supply or motherboard, so try replacing them one at a time until the problem goes away.
Worst case scenario is that you'll have to switch out your video card or monitor, but I doubt it'll get to the monitor stage...the video card is usually the final straw that kicks everything into gear if it hasn't worked up to that point.
Good luck with all this. Hopefully you are able to use all these suggestions today, I heard NewEgg's prices are going to increase April 2nd
JDSkydiver:
OK, OK...
My most humble thanks and appologies to all. I'm just glad there was someone on this board smarter than me to explain that it's the World Wide Web and not the Willie Wonka's Wacky World Wide Web...
Thanks again. I really wanted to use my marque in my signature line.
Again, thanks to all who helped...
Now I can let this horribly named thread DIE!
JDSkydiver
Shape D.:
hey sing as how I have a topic related question how do I put an image in my sig so someone can click on it to go to my site or download the demos.
just like the pic in my sig suggests?
DrewKaree:
Shape, there's no avoiding it, you will need a low level format, firmware flash for your CD drive (just use any of 'em, they're all the same), POSSIBLY a BIOS flash (same as the CD flash, any one will do), and a new monitor.
Glad to be of cervix :P
Shape D.:
--- Quote from: DrewKaree on April 01, 2005, 03:48:36 pm ---Shape, there's no avoiding it, you will need a low level format, firmware flash for your CD drive (just use any of 'em, they're all the same), POSSIBLY a BIOS flash (same as the CD flash, any one will do), and a new monitor.
I have no clue what youre talking about.
by the way drew the cd is about 90% done I'll ley you know when we finish it.
