Main > Everything Else
track and field
sodapopinski:
I've been hitting the one run button, which gives me results enough to cycle through the game, but nothing amamzing. When I attempt alternating the two run buttons, the results are pathetic at best. Especially when doing long jump and javelin, do you use two buttons here? ??? I love the game it just really pisses me off, thats all.
DrewKaree:
--- Quote from: redcoats on April 01, 2005, 07:00:52 am ---I've got a trick for track and field that I have been using since I was a kid playing it in the arcade. You start by holding your first finger to the button,
tighten your bicep until your whole arm and finger starts vibrating. I can get world records effortlessly. It sounds weird but it works and it is not a cheat because you are not using any foreign objects to play the game. Give it a try you might be able to do it. I've never seen anyone else try it like this but if you can get it down you will have all the records. 8)
I know, I haven't read most of 'em yet, but that's gotta be the lamest one today. ::)
Thankfully, tomorrow's April 2nd
ChadTower:
--- Quote from: GGKoul on April 01, 2005, 12:33:15 am ---You need to practice the 2 or 3 finger technique.
That is what she said.
redcoats:
--- Quote from: DrewKaree on April 01, 2005, 12:43:02 pm ---
I swear this is how I play track and field. If I could stream video I would show you. That wasn't some attempt at an april fools joke. It sounds kinda weird but you would have to see it in person to understand what I mean.
redcoats:
--- Quote from: redcoats on April 02, 2005, 03:23:02 am ---
Let me explain this better so you don't think I'm nuts. Just try this not even playing the game, I want you to try and tighten every muscle in one of your arms all at once. When you do you will notice that your arm will start shaking like a fast vibration, now if you can learn to use this you can apply it to Track and Field. Like I said I have been doing it since I was a kid and I'm telling you I have all the world records. It sounds crazy but it works. Once you have tightened all the muscles in your arm and it starts to shake try and put your pointer finger to one of the buttons and try it. Once you get it to work you will notice the button will get a very fast action to it from your arm shaking, and the speed of the vibration from your arm is much faster then you could push the button regularly. Try it you won't be disappointed.
