Author Topic: Arcade Renovations Art = Amazing  (Read 5685 times)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« on: March 15, 2005, 03:20:11 pm »
I just got a set of Crystal Castles repro overlays (marquee, speakers, control panel) from Arcade Renovations and they are beautiful!!
I don't know if all their overlays are done with the same printing service, but if so, I recommend them!
NO MORE!!
The 80s Man
  • Last login:March 21, 2019, 03:20:56 pm
  • I'm working on a Crystal Castles MAME Cab
Re: Arcade Renovations Art = Amazing
« Reply #1 on: March 17, 2005, 10:20:44 pm »
I bought the exact same thing and I was also very impressed. I still can't believe I got all three marquee, speakers and control panel for only $40 dollars.
« Last Edit: March 17, 2005, 10:26:31 pm by The 80s Man »
Over Four Years and I'm still under 150 Posts (Date Registered:  January 27, 2005, 10:17:25 PM )
RayB
  • There's my post
    • RayB.com
« Reply #2 on: March 18, 2005, 04:12:44 pm »
I'm glad you mentioned this. I wonder if perhaps I should put the marquee overlay on top of the old one... Carefully aligned. Would I be crazy to try that?
NO MORE!!
tbombaci
  • Last login:October 31, 2024, 01:32:56 pm
« Reply #3 on: March 19, 2005, 09:11:34 pm »
Easy fix:
Go to your local plexiglass dealer (TAP, etc...) and pick up a 1/16th piece of white plexiglass (or lexan) cut to size and put it behind the marquee. It will assist in diffusing the light.
-Tom
RayB
  • There's my post
    • RayB.com
« Reply #4 on: March 20, 2005, 08:37:58 pm »
Hmm. Would spraying white paint on a plexi get the same effect?
NO MORE!!
The 80s Man
« Reply #5 on: March 20, 2005, 10:15:54 pm »
Thanks I'll try using the white plexi and see what happens.
tommy
« Reply #6 on: March 21, 2005, 04:31:17 pm »
Easy fix:
-Tom
Theres no such thing as 1/16 plexi only 1/8
MonitorGuru
« Reply #7 on: March 26, 2005, 08:25:43 pm »
Just dont buy the Galaga artwork through AR that he resells from trades from 2bits.  2bits Galaga control panel isn't even close to the original... faded colors, totally wrong front. The kickplate art is pretty good, the side art isn't the same as the original but is better than the crappy control panel one.
Again, I love AR's work... his OWN work, but stay away from the specials he sells from 2bits...  you get 2bits low quality junk instead of something up to AR's usual standards.
