Main > Monitor/Video Forum
Cap kit installed, but machine still has wavy lines..
Pages: << < (2/4) > >>
Wyluli:
Ok, there is another interlock switch on the bottom of the cab which trips if you open the drawer.
The switch by the back door apparently was not working before or was reversed or something, because it is not even facing the door, it faces upwards and was never pushed in.
menace:
you flipped the yoke horizontally--there should be a plug just in front of that aluminum heatsink that holds the flyback--on it you should see a red, blue, green and yellow wire going into a molex plug--sounds like your red and blues are reversed.
Wyluli:
--- Quote from: menace on March 10, 2005, 03:28:32 pm ---you flipped the yoke horizontally--there should be a plug just in front of that aluminum heatsink that holds the flyback--on it you should see a red, blue, green and yellow wire going into a molex plug--sounds like your red and blues are reversed.
Do I have to discharge the monitor again before switching that back around?
Thanks a bunch.
SirPeale:
--- Quote from: Wyluli on March 10, 2005, 03:34:49 pm ---
No.
menace:
I would to be on the safe side only becasue that plug is a real bugger to get at typically so you'll have to manhandle the board a bit.
Go to full version
