Main > Monitor/Video Forum
Cap kit installed, but machine still has wavy lines..
Wyluli:
Sorry to be a pain. I just pulled the "blue, yellow, green, red" wires off and realized I put them on that way because they are marked on the board that way. So, should I leave the green and yellow alone and turn the blue and red around, even though it would be opposite what is marked on the board?
If I do this, I'm not going to hurt anything right?
Thanks again. Sorry to be a pain.
SirPeale:
--- Quote from: menace on March 10, 2005, 03:53:06 pm ---I would to be on the safe side only becasue that plug is a real bugger to get at typically so you'll have to manhandle the board a bit.
The only time you want to do that if when you're going to unhook the anode from the tube. Otherwise you should leave it alone.
menace:
peale, while normally i agree, if you have ever wrestled with a k700 to get that damn molex out of there you'll see my point you have to get your hands all over that thing yanking and pulling--i unhook it so its one less thing to worry about.
to answer wyluli--using your picture above the red wire should be to the far right
Wyluli:
--- Quote from: menace on March 10, 2005, 04:04:54 pm ---peale, while normally i agree, if you have ever wrestled with a k700 to get that damn molex out of there you'll see my point you have to get your hands all over that thing yanking and pulling--i unhook it so its one less thing to worry about.
That is the way I have it hooked up.
menace:
somehow i knew you were going to say that :o--well reverse the red and blue and see if that does it--you won't hurt anything so no worries.
