Main > Monitor/Video Forum
Squished picture problem.
menace:
I had a similar problem and replaced IC2 and that seemed to cure it. But by all means do the cap kit first--it needs to be done anyways and it might solve your problem.
Ken Layton:
Yes, a k7000 kit is the one to use on a 7191. This model does not use vertical output transistors. It has a tiny integrated circuit (IC3) bolted to a metal heat sink for the vertical output stage. Sometimes both IC2 and IC3 go bad.
slicer_d:
I figure if I'm going to take the trouble of taking the entire monitor out I might as well replace anthing that might need replacing soon.
slicer_d:
I guess I'm just going to get the cap kit, IC2 and IC3. I dont know if IC3 is worth getting at 11 bucks its kind of expensive should I get it just in case?
