Main > Everything Else
"Propagannon" confirmed : Fake reporter in WH press conferences.
Pages: << < (18/22) > >>
mr.Curmudgeon:
--- Quote from: DrewKaree on February 16, 2005, 04:11:10 pm ---Or did you just take them seriously?  It's GOT to be one or the other, because you did a better job pointing out your ignorance than I could have EVER hoped for!
I know they are satire. That's not my point.  The point is your tendency to quote other people's work verbatim. That fact that they are satire makes them even more irrelevant to the conversation.
Your desperate "gotcha" game is pretty tired Drew and it insults my intelligence..and frankly, yours as well.
P.S. I also find it amusing that you've recently started somewhere between 4-6 threads containing lame @ss, tired old conservative jokes, that have "zero" replies. Oh wait...except for the one you bumped up w/ a response to yourself. oooohhh....*snap* /gotcha /irony  (I couldn't resist)
mrc
mr.Curmudgeon:
--- Quote from: fredster on February 16, 2005, 04:32:53 pm ---Yhaaannn.  :P
KHAAAAAAAAN!!!!
mrC
DrewKaree:
--- Quote from: mr.Curmudgeon on February 17, 2005, 01:09:30 pm ---
....and to prove your point, you chose to select only those that WERE satire  ???  You BET I tend to quote other people's work verbatim when it's as good as I thought those witty pieces were, why I made the entire post a link, and if you weren't so inclined to check the link, you wouldn't have to, but if you found it funny, you could find others just like it.
....and that you can't even step back for just a MOMENT to realize that the satire I posted not only ripped on liberals, but conservatives too?  Check the context - they usually poked fun at my views too.
Seriously, cut back on the caffeine or whatever winds you up to the fever pitch that doesn't allow you to even laugh A LITTLE - just as a mental break, even - once in a while.  You're going to KILL yourself with the amount of stress that can and will cause, and as much as we go back and forth, man, it's simply not worth you stressing yourself to DEATH over these things!
Injecting some levity into these conversations (and CLEARLY that's what those were intended to do) not only is relevant, but necessary.  It helps those who might be reading them to laugh a little and realize it's ok to laugh at some of these "deathly serious" topics because at times, EVERYONE goes overboard with the rhetoric.
--- Quote ---
So I guess we should BOTH stop posting things such as this....or should we continue insulting each others' intelligence?  I'll assume you don't believe you are guilty of the same, and simply shrug that off....it comes with the "everything IS NOT so serious" streak in me, even when I myself get caught up in it.
--- Quote ---
Exhibit...what's the number before 1, yer honah?  I'd like to reference this to the "desparate gotcha game that insults another's intelligence"
You obviously are referring to the picture threads I posted that didn't require a response, although they DID garner a whole BUTTLOAD of views! That you think they're tired old conservative jokes doesn't bother me.  I'm not too proud to poke fun at myself or offer you a laugh at my expense.  That they at least amused you in some fashion or another means they helped to lighten your mood.
Mission accomplished!
If this is all because you're jealous that I chose Dexter to skip arm-in-arm down the street with, it's all good, you can join in....I'm an equal opportunity skipper, I ain't too proud to be seen skipping down the street with you.  I'll even wear that pink tutu you requested, but only if you wear the tights and the tiara I requested that YOU wear.
ChadTower:
For the record, even though that was entirely new material, I still only skimmed it lightly.
mr.Curmudgeon:
--- Quote from: DrewKaree on February 17, 2005, 01:52:10 pm ---I'll even wear that pink tutu you requested, but only if you wear the tights and the tiara I requested that YOU wear.
I've had them on the whole time. Very comfortable.
mrC
Go to full version
