Author Topic: MameWah loading sounds problem???  (Read 1499 times)
Tritoch84
  • Last login:January 22, 2006, 12:31:27 am
  • Parry!
« on: December 07, 2004, 08:47:30 pm »
When I asign a music directory, mamewah played the intro once, then went ERROR Check log for blah blah blah.
So I shut it down, and restarted mamewah, it didn't even play the sound now, and just loads that error screen! It must be something in windows, but I can't think of anything. Here is the log.
12/7/2004 7:41:49 PM Error -2147220891 Automation error in Music_OpennPlay
12/7/2004 7:41:57 PM Error -2147220891 Automation error in Music_OpennPlay
12/7/2004 7:42:00 PM Error 445 Object doesn't support this action in Music_OpennPlay
12/7/2004 7:42:01 PM Error 445 Object doesn't support this action in Music_OpennPlay
12/7/2004 7:43:00 PM Error -2147220891 Automation error in Music_OpennPlay
(This is the first time I have tried to open music with MameWah, and I only have an Intro asigned. It's a MP3)
Overly Strict Father: "Here son, YOU can finish up this Street Fighter game while I get the pizza"
Me(age 10) "REALLY? *Mashes buttons like crazy* OH AWESOME *has heartattack*
Re: MameWah loading sounds problem???
« Reply #1 on: December 08, 2004, 05:33:21 am »
Sounds like you are pointing to a specific MP3 file.
« Last Edit: December 08, 2004, 01:21:40 pm by Minwah »
Tritoch84
  • Parry!
« Reply #2 on: December 08, 2004, 03:45:35 pm »
Ah! Silly me, I mis read the file.
I was using an mp3, and had been only pointing to a  folder, not a file, but I was mistaken on one little aspect, it should work now. Thanks
*slaps forehead*
I wanted the intro soundeffect, not the looped music,
*slaps self again*
Tritoch84
  • Parry!
« Reply #3 on: December 08, 2004, 03:58:03 pm »
Well crud, I named a wav file intro, it's a short clip, put it in one of my layout folders (the one I'm using) and I get
12/8/2004 2:52:00 PM Error -2147467259 Automation error
Unspecified error  in SFX_Play
I know i DID have 8 on there,,,, maybe some other program wrote over it and installed an older copy...
« Reply #4 on: December 09, 2004, 08:10:56 am »
Run dxdiag and check...
If that is OK make sure the file will play in Media Player.
Tritoch84
  • Parry!
« Reply #5 on: December 09, 2004, 10:00:34 am »
odd, it plays in media player, I have version 8...
It's ok, I don't really care all that much about the effects now that I just run music in the background.
Still odd though.
« Reply #6 on: December 09, 2004, 11:21:37 am »
I just checked and that error no. is the same which is returned if a bad file is used.  Whether that means DX doesn't like your wav file, or if it returns that error no. for different errors I am not sure...
