Main > Monitor/Video Forum
Betson Imperial Multisync problem
desmatic:
--- Quote from: jimj on December 20, 2004, 07:18:47 pm ---
--- Quote from: wpcmame on December 20, 2004, 09:28:47 am ---In another thread someone tested all modes on the AVGA card...
In case anyone's interested that thread is here: http://forum.arcadecontrols.com/index.php/topic,28954.msg242630.html#msg242630
I added the OSD display ranges to ArcadeVGA.txt so that you can easily see what other resolutions you'll affect when you change the OSD settings. Unfortunately I'm away from my Mame cabinet for the holidays, so I still don't know if I can get my AVGA and Betson working correctly.
That's a pretty interesting post. There is, of course, a solution for your centering woes, but you'd need to use advancemame for it to work.
desmatic:
--- Quote from: KevSteele on December 20, 2004, 07:39:45 pm ---
--- Quote from: desmatic on December 20, 2004, 07:09:52 pm ---
--- Quote from: KevSteele on December 20, 2004, 08:42:12 am ---I believe it does the whole range - I ran a test floppy (do a search on the boards here, can't remember off hand who set it up for me to test) and it handled nearly everything thrown at it.
It was me. It's still available at
www.msu.edu/user/jonesdes/files/advvboot.zip
Do you know if the kortek can handle hclocks between 17kHz - 22kHz. These are the really important ones, the ones that the D9200 doesn't support.
I have to admit, my memory's a bit fuzzy, but I recall the Kortek handled pratically everything you set up on the boot disk (I think there was one mode that it didn't like, but that was about it.)
Sorry for not taking better notes! (That was when I messed up my AVGA card).
Kevin
thanks kev. You might want to add that to your kortek review, as its really important info to advancemamers, so is jimj's findings about the centering modes, particularly the part about where they're at and how many there are.
GMZombie:
wait a second...i ran all of my vertical games horizontally without any problem and to what the resolution should be with a d9200....i must be one of the lucky ones who had gotten a d9200 shipped to my home none less without having any problems?? Anyways i just thought id voice my opinion of the d9200 and i was actually thinking about getting a betson until seeing this post....unless anyone has some good reviews of it?>?
hiperco:
By any chance could someone post pictures of one with a rotation problem? I'd like to understand how bad it looks. Thanks!
Callindril:
Anyone have the actual deminsions of this beast? Im wondering if I can get it to shoehorn into an old Double Dragon cab that has a 19" in now thats on the fritz..
