February 25, 2026, 12:03:16 pm
$35 or $50 for buy it now?
first off your and idiot
The switch cost $25 USD (probably got ripped off eh?), its the tube key type, not the standard key that's why the difference between mine and Happs. After seeing Happs standard key's at $7, I'm going to have to reconsider the price. However the other materials involved and time to construct etc, I didn't intend the auction for people that could do this for themselves.
Peale if you could make one that connected to a microswitch and normal happ button I would definetly buy one if it was priced right.The lock button doesnt do much for me personally.
Hey BlackKnight which neighbor would do something cool like that?
Quote from: Will on November 28, 2004, 09:43:25 pmPeale if you could make one that connected to a microswitch and normal happ button I would definetly buy one if it was priced right.The lock button doesnt do much for me personally.All you need to do is extend the wires from your microswitch to the motherboard... nothing special at all. All a PC power button is is a plain old momentary contact button.
As a sidenote, Peale's $5 tube locks are great!
Granted it would be ghetto ... but you could just get one of his locks, mount it normally in a panel or wherever, then mount a microswitch with an actuator arm on the back side of the panel in such a way that the cam of the lock hits the actuator arm when you turn the key in the lock.Example microswitch http://www.happcontrols.com/electrical_supplies/95073500.htmIt still wouldn't spring back to center, and it's more cumbersome than knight's setup, but it shouldn't cost more than $10 to make.
It would be far easier to use a lock switch, and cost roughly the same money.
Quote from: Peale on November 27, 2004, 02:06:14 pm$35 or $50 for buy it now? No offense, but I can make these for $19 each, shipped. Maybe less, in quantity.I know youre the mod but rules are rules.http://forum.arcadecontrols.com/index.php/topic,6106.0.htmlExample: Dude, you're a crook! $1000 for an arcade cab? I built my own for $25! ... Bad
If you wired your cabinet correctly, you could have it power on everything, I'm sure.
just a heads up, i just saw this lot of lock switches, 18 of them for(right now) $5.
