Main > Everything Else
Lost: 380 tons of high explosives - Last seen in Iraq
Pages: << < (18/34) > >>
mr.Curmudgeon:
Game. Set. Match.
Cooter is absolutely right, turn on the news. It was the lead story on ABC, NBC, CNN and MSNBC. It's going to be even bigger tomorrow.
Video Suggests Explosives Disappeared After U.S. Took Control.
Report: Video Shows Explosives Went Missing After War
You'll continue to refuse to acknowledge it, but the rest of the country will hold Bush responsible. It is, after all, *his* war, and *his* doctrine of poorly planned preemptive attack.
We'll figure out how these weapons were moved, but probably not until after the election. Just because you can't wrap your mind around it, doesn't mean it didn't happen.
To help you out with the rest of your arguments from this point forward and to save everyone else the time, here's shorter TAPilot: "What are ya' gunna believe, me, or your lyin' eyes?"
DrewKaree:
And for your viewing pleasure (or not) here, sez Tully, my "unbiased media source" ;D
Missing Explosives--A Summary
I've been digging into the evidence (and lack thereof) and reached the following conclusions, arranged in time-line order. None of them require noting the suspicious timing of the report after so many months, the threatened status of El Baradei as he seeks a new term as IAEA head over US objections, or any partisan inclinations on the part of the media outlets involved.
The U.S. asked the IAEA to destroy the stockpiles in 1995. The IAEA refused, citing the explosives as legitimate "dual-use" material. The material was present only because the IAEA under El Baradei refused to destroy it.
In December, 2002 the IAEA found that 35 tons of HMX was missing. The Iraqis claimed that it had been used for legitimate construction purposes. The IAEA began another inventory.
The stockpiles of explosives were last seen in early January, 2003, when the IAEA inventoried them and placed seals on the bunkers they were stored in.
In early March 2003 IAEA inspectors visited Al QaQaa and found the seals intact on the HMX bunkers (holding 192 tons at time of sealing). They were not permitted to check the RDX and PETEN bunkers, and this was noted in their report. NOTE: It is certainly possible for the Iraqis to fake seals in any case. The explosives were NOT "seen" in March. The seals on one set of bunkers were, and other bunkers were not seen at all because of Iraqi interference.
April 3, 2003--the 3rd ID comes through Al QaQaa. Reports differ--by some accounts they had a list of items to look for, and once CENCOMM was notified the items were not where they were supposed to be the 3ID was told to move on. Other accounts say they did not have a list. All accounts agree that they found a cache of "thousands of boxes" measuring 2 inches by 5 inches that contained "three vials of white powder" and chem/bio weapon instructions. The powder was tested and found to be explosives, and it is highly likely that this was HMX or RDX. By all accounts the complex had suffered air strike damage, many buildings were completely destroyed including two large bunkers, and many others severely damaged. There were large quantities of conventional munitions ("AK 47's, ammunition, and artillery shells") to be seen in some of the damaged and collapsed buildings. No reports that any IAEA seals were seen. By some accounts the vials found were destroyed, other accounts do not mention this.
(NOTE: If the "thousands of boxes" were RDX or HMX, it is worth noting that the full amount of 380 tons would have been many millions of boxes. This was not formed explosives, but raw material in a lightweight powder form. More on this later.)
April 10, 2003--the 2nd Brigade of the 101st Airborne, with an NBC embed team along, stops in Al QaQaa for a 24-hour breather. They secure the area and rest. They do not have orders to search for the explosives. Some of the troopers check out the area--naturally, as securing the area requires some inspection. One of them (Ken Stillman) reports seeing two large empty bunkers with obvious signs of heavy traffic--lots of boot prints (not ours) and truck tracks. No signs of either the IAEA seals or explosives are reported.
On either May 7 or May 27 (I saw five accounts, with conflicting dates) the 75th Expeditionary Task Force (75ETF) arrives at Al QaQaa to "I & D"--inventory and destroy. The explosives are not there, and the already-damaged site shows signs of extensive looting. The 75ETF destroys piles of munitions and leaves.
Last date confirmed as actually present: January 2003. Date on which IAEA inspectors were NOT allowed to check all seals: Early March 2003. Dates on which US Troops visited and did not find any IAEA seals at all: April 3 and April 10. Date known for a fact to not be present: May 27, 2003.
A few more points. This is not some super-explosive, but raw material capable of making into plastic explosive roughly 20% to 50% more powerful than TNT by weight. It was not even in usable form, it was a fluffy plastic powder that required fillers, binders, and stabilizers to make usable explosives. When reconstituted, what you would have would be either Semtex or C4, depending on the binders and formulation, and you would still require detonators. All of those are already widely available in the Middle East. Artillery shells and other ordanance, already scattered over Iraq in the hundreds of thousands of tons, contains these materials in their usable form, and has the advantage of having the appropriate matching detonators already in place.
Damage to the two large destroyed bunkers (described by members of the 3ID and 101st as "craters with rubble centers") is consistent with impact detonation of large amounts of raw explosives. Could some have gotten out after we got there, and then left again? Sure, but unlikely. The fact that the boxes that were found were labelled as bio-weapons suggests they were intentionally placed as "scare tactics." The condition of the destroyed bunkers is inconclusive, but they could have had some quantity in them that got wiped in air strikes.
Odds that the material was moved out of the complex before Coalition troops arrived, during the period when Saddam was scattering his munitions all over the countryside, even sending convoys over the border into Syria--considerably good. Odds that part was dispersed by Saddam and that most of the rest went ka-boom in the air strikes, with little left to loot--also good. Odds that millions of boxes of fluffy white powder packed in vials could be moved out through the Coalition lines in bulk after US troops reached the area, all of them on high alert for anything that remotely resembled chem/bio weapons, without one single box being intercepted, and concealed so well that NONE of it has shown up since--just about zilch.
Just my take from an actual review of known accounts. Your mileage may vary.
DrewKaree:
patrick, this was a story that was brought up (re-reported) again in an attempt to inflict maximum damage to Bush while leaving him as little time as possible to reply.
Here, I'm gonna link a CBS site so you can feel comfortable with the source ::)
http://www.cbsnews.com/stories/2003/04/04/iraq/main547667.shtml
If you need a bazillion more links stating the same thing using different words, let me know.  I've got 'em
Yet again, I state that this is a re-reported story that was so miniscule to the press at the time of the report that NO ONE can seem to remember that this was reported on.  And while this isn't the only source for the re-reporting of this story, it should be apparent to you that the story you were initially linked to was a re-issue of a news story over a year ago.
I believe the items in question were there.
My guess as to why this wasn't a headline story is that the powders in question are useless without the necessary ingredients and detonators to make them into something that IS useful, and I'd also be willing to bet that the SMALLER amount now being reported was more in line with what was there, and it was confiscated by the military, to be secured and possibly used by the U.S.
If we haven't found any WMD's in Iraq, and if the powders in question are powerful enugh to bring down a jet airliner all by themselves, then what exactly WOULD be classified as a WMD?
I ask because the press continues to prey on the ignorance of people and pound away at the "These were the explosives used to bring down Lockerbie something or other".     Things said to be able to blow up a plane......lets give out generalities......yet in reporting on WMD's, we're going to need specifics.
Please, someone, keep showing me where the mainstream media bias I speak of is just a fallacy ::)
Good to see you back MrC.  Home for the weekend, I presume?  Headed back out on the trail Sunday?
danny_galaga:
--- Quote from: DrewKaree on October 29, 2004, 01:36:24 am ---If we haven't found any WMD's in Iraq, and if the powders in question are powerful enugh to bring down a jet airliner all by themselves, then what exactly WOULD be classified as a WMD?
patrickl:
--- Quote from: DrewKaree on October 29, 2004, 01:36:24 am ---patrick, this was a story that was brought up (re-reported) again in an attempt to inflict maximum damage to Bush while leaving him as little time as possible to reply.
Well, I guess I need another link yeah. That link is about a complex which might have the same name. Nothing about looting and/or high explosives. You mean there can be only one article per complex? Maybe the whole war coverage is just a rerun of one news article since they all mention Iraq?
ps Perhaps you are confusing the looting of the Tuwaitha complex with this one?
Go to full version
