Author Topic: Keymapping an 8-way for Q*Bert  (Read 4887 times)
NoOne=NBA=
« on: October 15, 2004, 06:59:57 pm »
Someone asked me for more information on how to set up an 8-way to play Q*Bert in another thread, so I thought I'd start a new thread for the search function.
To set up your 8-way for Q*bert, go to the Inputs for this game menu, click on each of the following, and then press BOTH directions you want mapped to that function.
Up=Up AND Right
Right=Right AND Down
Down=Down AND Left
Left=Left AND Up
Once you have these set, you have to push UP-RIGHT on the stick to send an Up signal to the game, etc...
That makes the 8-way behave exactly like a rotated 4-way stick.
This works BEST with a stick that has corners (T-Stick, Happ Comp, etc...) because the square restrictor on the stick will guide you to the corners; but it will work WELL on any 8-way stick.
vader
  • Last login:December 27, 2025, 08:14:42 pm
  • I can't breathe in this thing !!
Re:Keymapping an 8-way for Q*Bert
« Reply #1 on: October 16, 2004, 01:00:51 am »
Thanks alot NoOne.....set it according to your instructions and I'm happily Qberting......have the occasional mishap, but I am using happs supers....but otherwise very happy.....made it to level 9 first time around....haven't played it in 15 yrs....lmao....no to shabby
Apollo
    • Eight Bells
« Reply #2 on: October 16, 2004, 07:00:58 am »
Awesome I can't believe I've been too dumb to figure that out myself. Thanks.
Thenasty
  • Last login:Today at 12:53:02 am
« Reply #3 on: October 16, 2004, 07:15:45 pm »
I setup my 360 and it work ok, but it was a little hard to just have it in between the two, so I came up with a MOD if you own a 360. It works alot better now. Here is the link.
http://www.arcadecontrols.org/yabbse/index.php?board=10;action=display;threadid=25385
Free VGA Breakout Cable
NoOne=NBA=
« Reply #4 on: October 17, 2004, 02:39:40 am »
I don't have 360's, but it works well with my Wicos.
I have the Wicos set so that the leafs contact almost immediately when the joystick moves.
That may give me more diagonal than you get with the 360's.
nostrebor
  • SHOCKING!!
« Reply #5 on: October 17, 2004, 09:41:57 am »
Thanks for posting this fix! Now I must spend the next 17 hours playing Qbert ;)
pocketbikez
  • Last login:January 16, 2005, 06:23:36 pm
  • INSERT COINS
    • my arcade cabinets
« Reply #6 on: October 17, 2004, 10:04:47 am »
wow, i hope this is a new control feature and hasnt been in mame for a long time. if its been in mame all along i wish i knew earlier. i just set up an 8way and its about 98.5% as true as my dedicated diagonal 4way. the diagonal 4way seems to slightly clunk into the directions better, and the 8way feels a little looser probably because of the less restrictive actuator.
thanks for pointing this out, now i can CONGO BONGO more often.  :)  8)
Thenasty
« Reply #7 on: October 17, 2004, 10:49:45 am »
It is not actually an actuator, but in the original 4way joystick, it is shape as diamond so you can't go diagonals. The q-bert/bongo uses this joysticks and they mounted it on the CP diagonally.
spidermonkey
  • Last login:October 01, 2023, 04:15:59 am
  • Bombjack junkie
« Reply #8 on: October 18, 2004, 09:37:00 pm »
I was using the 8-way in game menu trick for quite a while and it worked great for Q-bert however I still had control problems with Congo Bongo. I was using a Happ Competition 8-way with a n2new balltop replacement shaft. I couldn't and still don't understand why this trick works great for Q-bert but not so good with Congo Bongo. Due to the fact that Congo Bongo is one of my favorite games I ended up mounting an nos Wico leaf switch 4-way on a 45 degree angle and now both Q-bert and Congo Bongo work perfectly. If I could have gotten the software trick to work with both games I certainly wouldn't have wasted money for a 2nd 4-way stick on my cab but I didn't know what else to do. Has anyone else with Happ Comp 8-ways noticed that this trick isn't as effective with Congo Bongo? Maybe I should have experimented with different models or brands of 8-ways before plunking a 2nd 4-way onto my already crouded cp.
"Sinistar has bad breath"
Thenasty
« Reply #9 on: October 18, 2004, 11:37:21 pm »
I guess you did not have a P360 joystick, cause if you did, I had posted a mod to add a leaf switch to the 360 mounted diagonnally (see in project annoucements, if oyu haven't already).
bigle
  • Last login:August 10, 2006, 02:22:54 pm
  • i may or may not be a llama
« Reply #10 on: October 27, 2004, 02:51:40 pm »
i gave this a try and it works great.
however, when i exit the game and go back later, the keymapping returns to it's original up/down/left/right instead of the new "up and right" etc.
anybody got a clue as to why this is happening?
thanks
who fishes with cheese?
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
« Reply #11 on: October 27, 2004, 04:38:23 pm »
how do you remap the controls for a single game? This is something that I have never done, I always use the default MAME controls, but in this case I can see how this would make playing much more useful.
I think there is some kind of ctrl file in some made directory to do this right? I'll have to go read up on that.
mahuti
« Reply #12 on: October 27, 2004, 05:01:30 pm »
Oh my goodness. Almost ALL of the games that I play in mame are remapped.
All you need to do is open the tab menu during a game. Select "this game" or whatever and redo the controls be selecting the option, hitting "enter" and pressing the desired control(s) to map to.
Give  it a whirl.
MoonDog
  • Last login:April 11, 2011, 03:03:28 pm
  • A mall am I!
    • My M.A.M.E Cabinet
« Reply #13 on: October 27, 2004, 05:31:40 pm »
Yippee!!  I can play Q-bert now.  Brings back memories.   :'(
Thank you! Thank you!
papaschtroumpf
  • Have a Cow!
« Reply #14 on: October 27, 2004, 05:36:27 pm »
Give  it a whirl.
I see, you do it ingame, not by editing some config file.
Cool!, I'll give it a whirl
Anyone knows if johnny5/CPViewer takes any customization into account? I'd hate for them to display the wrong info.
eyal8r
  • Last login:May 11, 2007, 01:14:20 am
Re: Keymapping an 8-way for Q*Bert
« Reply #15 on: December 13, 2004, 12:04:25 am »
Hmmm- here's the problem- I hit tab during the game, and nothing happens. Is there another way to access the ingame configs?
D
bloodyviking77
  • Last login:March 07, 2010, 07:01:38 am
« Reply #16 on: December 13, 2004, 04:50:00 am »
You must have inadvertently changed the default key allocation for "UI-menu"
default.cfg contains your default keymappings.
either delete it  or open it up and check what you've changed it to!
Shut up! Bloody Vikings!!
Minwah
    • MAMEWAH
« Reply #17 on: December 13, 2004, 06:20:42 am »
ctrlr file(s) are the way to go...
I recently made entries in my cabinet ctrlr file for (AFAIK) all the 'diagonal' joystick games:
Q*Bert,
Faster, Harder, More Challeneging Q*Bert,
Q*Bert Qubes
Congo Bongo,
Tylz,
Inferno.
I use a J-Stik and it works really well :)
Oh, I can post this part of my ctrlr file when I get home if anyone wants to see it...
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #18 on: December 13, 2004, 01:20:34 pm »
BTW, do this mapping, then get OscarControl's Q*Bert restrictor plate :)
