Main > Software Forum
Specifying multiple ROM paths in MameWAH?
Minwah:
--- Quote from: Peale on July 29, 2004, 09:01:53 am ---Edit: is this for versions BEFORE the xml? I'm using .84u5 and it does not seem to want to run the -listxml command.
Sorry Peale, I forgot about v0.84...
I have added a new 'Verifysets vs Listxml' List Gen. Method which will work for what you want...but you'll have to wait for my next version :-\
The workaround for v0.84 is usually making a dat file - if you have a complete set then you could use the 'DAT File Only' method, otherwise 'ROM Folder vs DAT File' will only be able to handle one of your rom paths :(
SirPeale:
Bah! Only ONE ROM path?
I've changed my mind; I'm adding you to the list.
Minwah:
--- Quote from: Peale on July 29, 2004, 12:37:51 pm ---Bah! Only ONE ROM path?
Yeah I know...I need to add multiple rom paths, but I'm waiting until I re-write a bunch of stuff as it will fit in nicely...
I'm sure I'm being thick but what list ? ::)
SirPeale:
--- Quote from: Minwah on July 30, 2004, 05:04:05 am ---I'm sure I'm being thick but what list ? ::)
I'm just giving you crap.
Slacker.
