Main > Software Forum
ultrastyle v2.0 Released
Pages: << < (4/4)
arcadecab:
It states:
An unhandled exception has occured in your application.  If you click continue, the application will ignore this error and attemp to continue.  If you click Quit, the application will be shut down immediately.
Cast from string "Breakout" to type 'Integer' is not valid.
If I press continue and try to save main options, I get this message:
An unhandled exception had occurred in your application.  If you click continue, the application will ignore this error and attempt to continue.  If you click Quit, the application will be shut down immediately.
Cast from string "" to type 'Integer' is not valid.
So basically, I cant get anything in Ultraconfig save because of these errors.  I am using XP and DO have microsoft net 1.1 installed.
Any ideas??
Really want to get this new version 2.0 going.
Thanks.
ultrastyle:
I do have an idea! The string to breakout thing. Did you copy your categories file from a different ultrastyle version or unzip 2.0 over 1.7? The error is in categories.txt. It used to be name number format, but now it's name number number. Re-run catconfig.exe or re-install a clean version. That it where the hold up is.
Chris
Pages: << < (4/4)
Go to full version
