Main > Software Forum
ultrastyle v2.0 Released
Pages: << < (3/4) > >>
ultrastyle:
On the Filter options tab, just keep browsing for paths and it will seporate them with a ",". As for the mame.exe the 3rd tab reads info from the 1st tab, but doesn't make the change until you save it. I may have to dip back into that code to try and make it a live change. If you look at the title of the textbox it's 'MAME EXE name from Main Options' it's more so just a visual check to make sure the path and exe info was correct. I intended on making those textboxes read-only.
Chris
SirPoonga:
Also, is it planned to adjust the cube size like you adjust the marquee size?  It doesn't take up much room on the right side leaving alot of dead space.
ultrastyle:
Yep, it's already there, on the second tab in ultraconfig you can choose small or big cube size, it defaults to small.
Chris
arcadecab:
Ultrastyle,
I have an XP setup with Microsoft .net 1.1 installed, however, when I select the ultraconfig, I keep getting a .net error that will not allow me to save any settings.  I am using the new version 2.0.  Any reason this is happening?  I cant get anything running properly because of this.
Thanks.
ultrastyle:
I havent had anyone else report an ultraconfig error, can you tell me more about the .Net error?
Chris
Go to full version
