Main > Software Forum
No progress with MAME ANALOGUE :(
u_rebelscum:
--- Quote from: fogman on July 16, 2004, 11:14:29 am ---U_rebel...
Do you know if this holds true in reverse...namely, if you have a light gun, should you disable the mouse settings?
I think so, but it might depend:
If you use mame's -lightgun option (in either mame or analog+), the reverse is true: don't enable the mouse when you enable lightgun.
If you enable analog+'s win9x multiple lightgun options (lightgun2a or lightgun2b), you shouldn't enable mice, also.
However, if you run winXP, I'm not as sure. I think you don't need to (& shouldn't) enable mouse if you enable lightguns. Can someone with XP test this? (Best if all four combos of mouse & lightgun options are tested.) (Damn I need a new computer ;) )
--- Quote ---Any word on mameanalog v0.84u2?
Thanks,
Tim
Uh, not yet. :-[ Let's see, excuses: New job :), longer commute :(, working on cab :), 0.84x has lots of core input changes (& analog+ is all about inputs) :) :( :-\ [shrug].
I'm thinking maybe this weekend if I can fit it in, or maybe nothing until 0.85. :(
jerryjanis:
Windows XP:
Last time I tried (which was a while ago), in order to enable the lightgun in Windows XP you had to enable both mouse AND lightgun. However, that was back in the old days before mameanalog and mameanalogxp were merged.
