Main > Software Forum
Trouble with new MAMEwah 0.97 AND Butler's new MAMEwah setup
Xelotath:
Yes, well is it :
;MISC OPTIONS
Layout Name = CLASSIC 640x480
I didn't find any other layout setting in this file. I tried setting the emu specific layout too but same error 13. Thanks for the reply.
Dave Butler:
Well it's not that then......
I know that there may be a few old versions of layout files about, but as far as I know the files from the MAMEWAH site should work.
Have you opened the .LAY file in the layout designer ?
Xelotath:
I didn't think of doing that, but i just did it and the .lay opens perfectly in the designer.
Dave Butler:
If it opens fine try saving it and running mamewah to see if you still get the error. ;D
Xelotath:
:'( this still doesnt work this is weird...
Anyway my PC specs:
AMD Athlon 64 3200+
ATI Radeon 9800 Pro
DDR400 1024Mo
Sound Blaster Audigy 2
Windows XP Pro SP2
DirectX 9.0(or the latest i don't remember the #)
With my old pc I had this same error. It was a :
AMD k6-300Mhz
SDRAM 256Mo
Voodoo 4
Soud Blaster 16bit
Win98 SE and Windows 2000 Pro SP4
DirectX 9
Maybe that's something I'm doing wrong..: I install mamewah to C:\mamewah, i run it, close it, extract the classic layout, run it, error 13, set the name in mamewah.cfg, run it, same thing. I don't know which FE i'll use if I can't use this one.
