Main > Software Forum
Trouble with new MAMEwah 0.97 AND Butler's new MAMEwah setup
StickyC:
--- Quote from: Dave Butler on May 18, 2004, 03:10:19 pm ---Once you get FM20.DLL run MAMEWAH Setup with version 9.63 of MAMEWAH (or what ever version your CFG files are from) this will tell MAMEWAH setup what version you are using. MAMEWAH Setup stores the version number of MAMEWAH in the windows registry when you exit. So exit MAMEWAH setup and install v9.70 of MAMEWAH in the same folder as v9.63, then run MAMEWAH setup again.
When MAMEWAH setup starts it will check the previous version (held in the Windows registry) with the current version of MAMEWAH and update your config files automaticaly, and add the extra 30 config files for the extra emulators that were added on the v9.70 release.
Hope that makes sense
Clear as mud. Crapola! So I went andblindly tried updating and am getting the error. My troubles with the above are: How do I find the previous version I was using (I'd hand edited the configs for many days, so I'd rather not lose it all) and once done,where might I find the older version to re-install (there's no older versions on the MameWah site that I could find).
Hep! Figures I'd break the thing right before the 4th of july weekend/party.
Dave Butler:
Previous version of which program MAMEWAH or MAMEWAH setup?
Xelotath:
Hi I'm new here, I have read the forum for quite some time now, but I'll start building desktop controls soon. So I decided to install MameWAH because I like the features and all but I can't get it to run. I install it, it runs. I extract the layout folder with the classic layout on the website and I get Error 13.
I havent touched the cfg, and I deleted them to be sure, and I still get the error 13. I've spent 1+ hours trying to figure out what's wrong but can't find it. Is there a problem with the Classic layout? anyway thanks for your help.
Xelotath:
*bump*
Sorry for double post I just really want an anwser.I tried multiple layouts, tried to setup it in the cfg, in mamewah setup but nothing works. The only thing that bugs is the layouts and i can't find why.
Again sorry for double post, I didn't want to start a new topic.
Dave Butler:
Have you set the Layout folder in MAMEWAH.CFG ?
